Netgear DG834GT - bad Teapo SC causing catastrophic damage
  • japlytic
    • Oct 2005
    • 2086
    In a Netgear DG834GT wireless ADSL modem, there were some bulging Teapo SC units.
    Replacing all of them did not fix the problem, but the diode at the DC-DC coverter near the 470uF 6.3V unit was shorted, along with the DC-DC converter.
    So replace all of the Teapo units before it's too late!
  • Agent24
    I see dead caps
    • Oct 2007
    • 4981
    • New Zealand
    Re: Netgear DG834GT - bad Teapo SC causing catastrophic damage
    Did replacing the diode and DC converter fix it?
    -David VanHorn
    • japlytic
      • Oct 2005
      • 2086
      The IC was a MP1410, which is hard to obtain in my country, so this unit was written off.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4981
        • New Zealand
        That's a pity. There's MP1410 on eBay but not SMD (for a decent price) which I assume is what the router uses.
        -David VanHorn
        • severach
          • Aug 2007
          • 1055
          Unless you tested the diode for shorts out of circuit, the diode, MP1410, and the P-MOSFET if equipped are likely to be fine. Those are the strong parts that can handle 25v or more, more than is available from the transformer. What is at risk when the ripple skyrockets from bad capacitors is the weak parts. Chips requiring the common low voltages: 3.3v, 2.5v, 1.8v, 1.5v, 1.25v, and many more are not going to be very resistant to over voltage so will burn out easily.
          The diode near the SMPS chip is backwards across the supply rail through the inductor. If any part on that rail is shorted, that diode will show shorted to DC from the test probes. I've been testing a lot of routers and on occasion I mess up. Sometimes shorting the supply out makes the SMPS chip overshoot to recover. Sometimes I forget to discharge a test capacitor when moving from a higher to a lower voltage. Voltage goes up for a brief moment and shorts all the main chips out. The SMPS senses the short and locks out.
          For small devices 3.3v is the most common voltage from the head SMPS. When the multi voltage chips short out, they can short 3.3v onto the lower rails shorting some of the chips that aren't directly hooked to 3.3v.
          sig files are for morons
          • iMic
            IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
            by iMic
            Hi folks,
            I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
            The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
            11-29-2023, 06:44 AM
          • Joel Ohana
            Lenovo IdeaPad 3 15IAU7 that suffered water damage
            by Joel Ohana
            I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
            Symptoms:
            • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
            • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
            What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
            03-06-2025, 11:25 AM
          • gripa
            looking for netgear WN2500RP schematic
            by gripa
            I am looking for a schematic of the netgear WN2500RP repeater.
            best regards
            12-17-2024, 12:39 PM
          • azozexd
            Need help hp 725 g3 liquid damage
            by azozexd
            Hello freind i have hp elitebook 725 g3 White liquide damage
            after cleaning the board i find à damage resistor white no value i test it not reading in multimeter
            could some one tell me the value of this resistor
            Thank you...
            12-15-2024, 06:01 PM
          • mon2
            A1466 Macbook Air (Liquid damage repair)
            by mon2
            Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
            Macbook AIR Model A1466 Diagnostic 09-01-2021
            Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
            Problems & Resolutions
            1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
            09-01-2021, 09:31 AM
