Wireless woes that I have sorted out over the past year.
  • Brian10962001
    • Dec 2010
    • 6
    I read through some of these threads, and instead of bringing up months old threads I figuered I would start a new one. My wireless trouble started when I set up a streaming network in my home. I have an Xbox 360 wired in the living room, Xbox 360 wireless in the bedroom, 2 laptop PC's, my main PC in the living room (all 3 wireless) and frequently would have visitors over who would use the wireless. The trouble I started having was that I would frequently have to reset the router and modem, supposedly because of conflicts with my cable modem (Motorola surfboard that I own, router is a Linksys WRT54G of some variety that Vonage gave us years ago).
    I live in the country, and for the longest time I was the only person on the node, talk about FAST! Well I noticed degredation in my speeds, and obvious problems with the modem/router conflicts for a long while. I first set wireless security, WPA but this is a HUGE hassle when dealing with steaming because if it tried to renew the lease with a device that wasn't active at the moment, it would fail (device would show but wouldn't allow you to access it). I set static IP's for everything, and put them out of the range of the auto assigned IP's, still kept running into issues. I had someone tell me that my router didn't play nice with the Comcast cable, so I purchased a new Rev 1.0 WRT54G (the sleek black one with no antennea).
    This got me up and running, but still had the issue with the WPA and still would get the random disconnects and modem troubles. Finally I found a program called inSSIDer and ran it, MAJOR problem found! My neighbors had apparently all upgraded to high speed, and 4 out of 5 were broadcasting wireless on channel 6! One person was broadcasting on channel 12, so I dropped mine to channel 1. After this I disabled the WPA security, and since then I have been set. I have reset the modem/router maybe 3 times in the past few months, and while I'm a bit nervous about no security, I live in the sticks and have been dealing with it. If I ever get to nervous, I'll restrict the router to only allow access to manually added IP's
    I see a lot of talk on here about flashing firmware, or re capping, but here's the crazy thing, I gave the old Vonage router to a friend of mine who lives WAAAAY out in the woods (but just close enough to get DSL) and it has been flawless for him ever since. This router is at least 4 years old with no firmware update, and it is still kicking. While I agree you should stay current on these things, It never hurts to check the small stuff first.
    Finally I wanted to add that one of our laptops will give the random "no network found" error that for the longest time I blamed on the router, turns out the wireles B (yes old school) mini PCI card is dying, 15 dollar fix and I get upgraded to wirless G speed.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Wireless woes that I have sorted out over the past year.
    You urban parasites, who has to pay for all that wire run to your utopia in the boonies?
    Now, regarding the router, there are two things that should concern you.
    I sold two Asus WL-500G Premium V1 routers that I flashed with Tomato to two seperate people. Both of the routers failed. I gave them different routers, and I have had these routers sitting here for a while. Recently I decided to do some recapping. No go. So I tried the short pin 9 of the IC to ground, that didn't help.
    Finally last week I hacked the wire off of an old DC transformer and soldered it onto a 5V 2.5a switching adapter and both routers work great. I installed the absolute latest OpenWRT Backfire that I found on their server and it works great.
    So you should recap your routers and open up the adapters and change the cap in there too. Those adapters especially will fail after a while. As for custom firmware, you might find OpenWRT's LUCI GUI a little complicated. I recommend you use Tomato and NOT DD-WRT which will be slower than the original Linksys firmware. The thing is, I'm pretty certain Tomato is based off of the old 2.4x kernel OpenWRT release, so, while it works great, the later 2.6x firmwares are faster they say.
    I can't vouch for B43 maturity, as I think your router is also Broadcom like mine, because I haven't done any tests on it yet.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      he isn't a parasite. he lives out that way and he was offered service? the company already ran the wire so why the hell not?
      if things are working i would leave it the hell alone. if you get issues, recap it.
      i have a router running ddwrt... it seems to work well. only thing is you have to be good with FTP'ing things... if the stock FW is fitting your needs, again, leave it alone.
      the power bricks can be fishy... if you have issues, switch bricks/warts.
      as long as you stay far, far away form belkin, you should be A-ok.
      sigpic
      (Insert witty quote here)
      • NxB
        • Feb 2009
        • 1595
        Firmware: DD-WRT v24-sp2 (10/10/09) mega
        [UP] Time: 11:21:46 up 16 days
        Say what you want about DD-WRT. This is the 32MB router. It was reset when the internet went down (was an ISP issue. WPA2 AES and at least 4 clients.
        • mockingbird
          • Dec 2008
          • 5484
          NxB, which router do you have? I'd be glad to run a simple benchmark and totally pwn you with OpenWRT.
          • MixMasta
            • Feb 2006
            • 142
            How are you going to benchmark a router accurately I wonder? I use dd-wrt. All the crap I hear about how slow it is has mostly been fud. Your barebones OpenWRT install that didn't even support broadcom's wireless until about last month is faster than mine? Good for you I guess.
            • NxB
              • Feb 2009
              • 1595
              Benchmark away. I was looking for a program earlier, i want to tweak.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                as long as it works i am happy... mine the last i checked (at another house right now) used about 92% of the cpu... no slowdowns.
                sigpic
                • mockingbird
                  • Dec 2008
                  • 5484
                  dd if= of= /mnt etc... from shell would do the trick, no?
                  I'm not talking about wireless, B43 support stinks, I would do it through the switch.
                  Another thing, B43 has been supported for a while. It hasn't worked well, and it probably doesn't work too well now either because it's not open source, it's a binary, but Asus WL-500P has a removable mini PCIe, so replacing it with a well supported Atheros replacement is trivial.
                  • NxB
                    • Feb 2009
                    • 1595
                    But wireless is what we use. I have some wired stuff but the way my home is set up precludes an ethernet run to the bedroom. If it was only about wired performance, I wouldn't fuck around and just get a cisco.
                    I've been wanting to do throughput testing but I can't find a good utility. I know they are out there. PC to PC sustained bandwith is what I'm looking for. For some reason I only get 30% signal strength 20 feet away router to router. Could sticking the router on the floor cause this?
                    • mockingbird
                      • Dec 2008
                      • 5484
                      You're missing the point. We need to first test the router's routing performance. which interface it uses is irelevant. How efficient the router is, how fast it is, is irelevant of which wireless chip is inside it.
                      That's why wired test through the switch is reliable.
                      • NxB
                        • Feb 2009
                        • 1595
                        But thats just one test. I know there are throughput testing programs. It would give a real world test vs just dd'ing files to eachother.
                        • mockingbird
                          • Dec 2008
                          • 5484
                          We're not testing the hard drive, we're testing the transport method. Simple file copying is perfect and more than enough. The only thing we have to watch out for is caching, so we can do 3 different files of different sizes.
                          • Brian10962001
                            • Dec 2010
                            • 6
                            Well guys I got another gremlin!!! I don't know if the crazy weather out here is causing the electric to be flaky or what, but the Linksys WRT54G2 is dying on me. I am pretty sure this one IS the caps inside causing my problems because it smells strongly of burnt electronics. I'm going to get a loaner router off ebay (probably a refurb wireless N of some kind) and pull this one apart to see what's going on inside.
                            • mockingbird
                              • Dec 2008
                              • 5484
                              Check the caps inside and also crack open the switching wall adapter if you feel adventurous. Alternatively, you can scavenge a power brick from a different router. They are something like 5V and 2.5A. Make sure the polarity is good. If not, just do some surgery on the cable and switch the wires around. If the plug is too thick/thin, then scavenge one from any old wall wart that fits.
                              • Brian10962001
                                • Dec 2010
                                • 6
                                I opened this, and another WRT54G2 V1 router today, there are 2 caps, both su'scon 220uf 25 volt. Both routers caps look intact, no swelling or leakage that I can see. Both of the routers look pretty toasted under the Broadcom chip, they've actually discolored the PCB. I'm not sure if someone bricked the other one, I've had it laying here for a while and decided to open it, it lights up but I get no connection through it.
                                • Brian10962001
                                  • Dec 2010
                                  • 6
                                  OK, very strange and slightly profound discovery just now. I had been planning on replacing my router, or recapping it, but I just had a feeling this wasn't my issue. I did end up replacing the power supply (which was putting out 11.9 volts at no load!) with a 1 amp power supply from an old set of PC speakers had, VERY overbuilt for this job .
                                  Anyways, I started thinking, what have I changed around the time this problem popped up, and oddly enough, the only thing I had done was to install an updated driver on my Acer Aspire One laptop (aoa 150). I wouldn't think this could cause the problems I was running into, but I did some looking and found out that in fact it can!
                                  The problem apparently lies in the fact that even with the most recent firmware, my WRT54G2's can't support IPv6. This causes problems when you have uPnP running on your router. I fist disabled IPv6 which seemed to work for a minute. Next I turned UpNp off in my router and so far I've ran into no more issues. I'm guessing that the new driver for my wireless card somehow changed the way my PC was handling the IPv6 and this started the problems I was having. I checked my wireless sharing today, and it still works and man is it fast now! Hopefully this fix hold up, was really running out of ideas on this one.
                                  • double_DD
                                    Why does my ISP router hate my "homemade" power supply??
                                    by double_DD
                                    It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                    So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                    For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                    07-12-2025, 03:09 AM
                                    HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook 800 Specification for Upgrade or Repair
                                    This specification for the HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Backpack & Wireless Premium Mouse boardview and 840 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                    09-06-2024, 03:30 PM
                                    HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
                                    This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                    HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook 400 Specification for Upgrade or Repair
                                    This specification for the HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Backpack & Wireless Premium Mouse boardview and 430 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
