Td w9970v3
  • DUNC4N
    • Dec 2014
    • usa
    Td w9970v3
    hello, I am looking for dump firmware suitable for this modem, there is also remont aud, but I could not download it, can anyone help?
    TP-LINK
    TD W9970V3
    F59L1G81MA NAND FLASH
  • tranquility
    Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
    by tranquility
    i want to repair an Onkyo TX-NR809 receiver.
    symptoms:
    on power on, display appears and i hear one click. enue functions is given.
    - no hdmi output
    - audio output not tested, but i think it is not there
    - usb sticks are not recognized
    if i read out the chips with display+standby button + tone+
    both dts show only ????
    chip is D830K013BZKB4
    things i have done:
    - reflow of the dts chip without taking off and reballing
    - changed the aluminium caps without the big one with 25v because i dont...
    08-25-2025, 01:04 AM
  • mattpd
    PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
    by mattpd
    PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
    No LM damage. UART gives a generic "APU not responding" error.
    Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
    I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
    So to those with experience, would you expect at least a little heat from the NAND during...
    09-02-2025, 09:42 AM
  • sohail5307
    Need a2159 128gb nand bin file
    by sohail5307
    I have received SSD nand short A2159 macbook. I received new tsb4226 nand , but i think this is removed from iphone, I have nand programmer , if anyone have nand firmware please send me
    Two nand are using :
    Tsb4226(128gb)
    Tsb4226(128gb)
    09-16-2023, 09:20 PM
  • tech_guru
    Macbook Pro 2019 A2141 NAND Shorted
    by tech_guru
    Hello. If you could please help me understand what I am doing wrong...
    This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
    I also replaced the tps power ic for the ssd.
    Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
    08-28-2025, 08:04 AM
  • kenzo2
    Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
    by kenzo2
    I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
    I need dump file MACBOOK PRO A2159
    TSB4232(256)
    TSB4229(256)
    Thanks​
    01-11-2025, 04:18 AM
