Re: Dell 2007WFP Won't Power On
Yes that's correct, I get 0v to the tabs, only voltage is on the 2 soldered legs
Originally posted by croket View PostYes I did measure all 4 the j598s, I get 19v to both the legs on all them. The row of fuses stamped with "G" have no voltage getting to them.
PlainBill
It has to be on the USB board
There is a row of fuses that look to protect the circut going to the small usb conector,they have a 'G' stamped on them.
Have you measured the voltages on the pins of the J598s?
Ok so your logic board is getting the same voltage on the pins as mine without the big USB board attached, so its safe to say the problem is isolated to the USB board. I don't get the 5v at the 'G' row.
PlainBill, sounds like your on to something with the gates not opening.
It can get confusing; I will call the USBs big and small.
The small board doesn't have to be installed for the big board to generate voltages for the signal board.
However 5 volts is on the row of ‘G' fuses going to the connector for the small board.
If we are interpreting things correctly, crocket's board should be providing power to the signal card whenever the power supply is plugged in. The USB jacks will not have power unless a device is plugged into them.
PlainBill
I will re-check a little later to make sure,but i think every thing is dead without the USB pulged in.All of the tests were done without the small USB board installed.
Alexanna, if you power up just the logic board (with out the usb board) which pins have voltage & what do they read?
Originally posted by croket View PostOn both U3 and U4, Pins 9 show 18v and pins 15 show 0v. The connector at the end of the board is for the actual USB ports (2 ports mounted on a small board with 4 small caps). That connector reads 0v on all 8 pins.
PlainBill
Originally posted by croket View PostRetiredcaps I re-tested with the USB board disconnected but had the same results.
I've uploaded some additional pics, one shows the bottom side of the usb board indicating the pins getting voltage,(took the picture first then plugged the board in) the other is the U2 chip. The 4 IC's with 19v are part# J598.
I'm trying to be as detailed as possible with pictures guys , but if its too much I'll tone it down. I figured pictures tell a thousand words!
Thanks for jumping in on this Plainbill and Pedro.
Which brings us to the next step. What are the voltages on pins 9 and 15 of U3 and U4? Does 19 volts appear on any of the pins of the white connector on the left side of the USB board? What connects to that connector?
Briefly, these boards are a step back from what I was expecting. U3 and U4 are dual pulse width controllers. The J598s are 2SJ598, a P-Channel FET.
PlainBill
Originally posted by PlainBill View PostNext, what are the voltages on each of the 12 pins connecting the signal card to the USB card?
There are 4 regulators you have indicated have 19V on two pins. What are the part numbers of those 4 ICs?
Last, what is the part number of U2 on the USB card. What is the voltage on the three pins?
PlainBill
Originally posted by pedro View PostThe USB board obviously produces a regulated +5V from the 19V supply. Is it a possibility that THAT is the supply for the logic board, and NOT the 19V? If they are going to use 3-terminal linear regs for 3.3v etc on the logic board, that would make sense.
