Nec Multisync FE700+
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    I got today that crt monitor and was planning to give it to a friend, but when tested it I noticed some discoloration in the upper right corner of the screen.
    It can be seen in the photos that the chassis is broken there..
    How do you explain the discoloration?
    Is it fixable?
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Nec Multisync FE700+
    tried degaussing it?
    some monitors have an option in the menu for that..
    • Krankshaft
      • Jan 2007
      • 2328
      Looks like somebody was playing with a magnet.
      If the internal degaussing doesn't work as it sometimes won't if the screen is really magnetized you'll have to use an external degaussing coil.
      Power it up and slowly rotate it in a circular motion while stepping away from the screen. Once you're far enough away and don't see it effecting the deflection anymore turn the coil off.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Degaussing and on offs didn't help.
        Where can I find an external degaussing coil?
        • PlainBill
          • Feb 2009
          • 7034
          Sounds like it could be a warped shadow mask.
          PlainBill
          • Scenic
            o.O
            • Sep 2007
            • 2642
            thought about that too.. as it looks like the monitor fell onto that edge.. :/
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              PlainBill
              it uses aperture grill.
              • PlainBill
                • Feb 2009
                • 7034
                Semantics. The monitor was probably dropped on that corner, distorting the aperture grill, shadow mask, or whatever you wish to call it.
                If you can easily borrow a degaussing coil, it's worth a try, but it's unlikely to actually help.
                PlainBill
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  I used a screwdriver with a magnet to test how the monitor responds when you get it near it.
                  I read over the internet that some people attach small magnets at their monitors in a way that the discoloration is less visible.
                  So, I put the screwdriver at the top right of the screen and the discoloration went away but it was temp: When the magnet was removed it got back.
                  Then I had the idea to degauss it while I had the screwdriver on it in a way there was no discoloration but that had the opposite results: The discoloration got bigger when the screwdriver was removed.
                  So, what I did was to put the screwdriver in a way that the top right corner of the screen was completely reddish and then degaussed. It instantly became less discolored and after I removed the screwdriver, the screen's colors are nearly perfect!!
                  I don't know if this is a temp fix and it will get discolored again over time... Time will tell.
                  What do you think?
                  • PlainBill
                    • Feb 2009
                    • 7034
                    What do you think?
                    I think you have magnetized it in a matter that compensates for the warping of the mask. The normal degaussing action the monitor uses when turned on will remove it. The distortion will return fairly quickly.
                    PlainBill
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      You were right...
                      • PlainBill
                        • Feb 2009
                        • 7034
                        You were right...
                        Well, nobody can say you didn't give it a good try. Too bad it didn't work out.
                        PlainBill
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          Thanx for your help anyway
                          • vexarvf1s
                            Is it Fixable? Lenovo Legion 5 15ACH6H
                            by vexarvf1s
                            Hi Everyone,
                            I got in a Lenovo Legion 5 15ACH6H.
                            It was a nice gaming laptop with a Ryzen 7 5800H and RTX3060M, however; a screw came loose and shorted things out.
                            PSU is good. 20V to board. No power on any power rails. Power rails are not shorted to ground.
                            An unknown gate at location UI130 is blown up and I do not know what it is to replace it.
                            Caps near PL6202, PQ3002, PU7901 are all blown. If anyone can help me with the correct values to theses capacitors it would be very helpful.
                            The ITE3176FN-56A IC at location U122 has a hole in it and I will...
                            03-20-2024, 02:23 PM
                          • Rubenlily
                            Samsung 65" 4K (don't know model) - is this fixable?
                            by Rubenlily
                            I don't have much info. Seller doesn't share much but says it hasn't been hit or dropped and that it just appeared by itself.
                            Is it fixable and how much should I pay to buy it in this condition?...
                            08-23-2023, 09:15 AM
                          • YellowJacket
                            Asus VX238H - pink area over picture
                            by YellowJacket
                            Hi friends,
                            I got this monitor, which works perfectly fine, except there is pink discoloration over right side of the screen ( picture1 ). When I disconnect LVDS cable, there is no sign of pink color, so its not backlight issue ( picture2 ). I took a closer picture of the upper right corner, you can see even some kind of pixel defects. Its only on that pink area ( picture3 ).
                            I believe, there is some problem inside the panel, the question is, if it is fixable. I have never met this kind of issue, so I really appreciate little help from you guys. What I tried so far - interrupt...
                            08-17-2023, 11:45 PM
                          • ptcriserx3
                            Sony trinitron crt bowed and side color issues
                            by ptcriserx3
                            Hi
                            Ive got a vintage 2001 sony trinitron flat tube tv
                            The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                            See many images attached...
                            Just windering if this is not fixable or something i can correct without getting too invloved
                            Im trying to sell the tv
                            06-17-2023, 07:27 PM
                          • ja1870
                            Intermittent Samsung H4000 TV A/V problem. Failing component, or "reset" fixable?
                            by ja1870
                            As probably no symptom is unknown to those around here, would appreciate any comments.
                            Trying to troubleshoot an intermittent condition for a non-technical senior - remotely.
                            When I can get over there, will try a factory reset, but suppose it could be a symptom of a failing cap or other component - and prefer to be forewarned either way, if possible.
                            Detail:
                            Older 28" (non-Smart) flat screen Samsung UN28H4000AFXZA works perfectly, except when occasionally displays one of two - probably related - symptoms.
                            1) Channel displays...
                            03-15-2023, 05:17 PM
