Viewsonic VA1616W driver board burned
  • R_J
    replied
    Re: Viewsonic VA1616W driver board burned
    Have you checked the values of R9, R12 and R15? that may not be your problem. Check the voltage on (1_8AVCC1)1.8v and (3_3VCC1) 3.3v
  • lotas
    replied
    Most likely I connected the VGA cable to a hot one (the laptop was connected to the network via an adapter and the monitor was connected to the network).
  • R_J
    replied
    It seems odd to me that connecting the vga cable did this, there should only be video signals of around 1v p/p on these lines.
  • r38_
    replied
    Originally posted by R_J
    Is this not the same board? https://www.aliexpress.com/i/4001097110422.html, You may need to swap the spi ic U6
    Yes, that's the same board. Unfortunately, the board + shipment + import costs, the final price is $60~, which i think is not worth it for a 15' lcd monitor.
    Anyway, thanks for the help!
  • R_J
    replied
  • r38_
    replied
    The resistors are likely 75Ω, but they won't be the problem, I suspect the ic that is connected to these lines has been destroyed. Buy a new replacement board from aliExp.
    I thought about it, but i didn't found any replacement board in aliexpress or other sites
  • R_J
    replied
    The resistors are likely 75Ω, but they won't be the problem, I suspect the ic RTL2525LH that is connected to these lines has been destroyed. Buy a new replacement board from aliExp.
  • r38_
    replied
    give it a good cleaning
    I found board schematic, what value would be r12 and r9?
  • petehall347
    replied
  • r38_
    started a topic Viewsonic VA1616W driver board burned
    Hi everyone, i connected my va1616w monitor to netbook and it burned components of the driver board in the vga port area, i think i bad connected the cable by mistake. After this the monitor power on but never receives signal from computer or any connected to vga port.
    I didn't find schematics of the driver board. Also i tried a universal lcd controller (mt6820-t) board with the panel but it was not supported. This is repairable or the board is dead? Thanks in advance. Images of the board:
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Hink85
    Samsung UN65RU8000FXZA Led Driver Board
    by Hink85
    Hi All,
    I picked up a Samsung UN65RU8000FXZA 4k Smart TV a few weeks ago, in hopes I could repair it and get it working. It was purchased in Nov 2019, Samsung already replaced this tv by the original purchaser.
    I have eliminated the main board and power supply, and back lights are working. It was cycling on and off when i got it, I disconnected ribbon cables until I pinpointed it down to an LED driver board, and with the suspect board or ribbon cable section, 3/4 of the TV will now stay on and it no longer cycles on and off. I haven't found any shorted capacitors...
    08-12-2020, 07:03 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
