Alienware aw2721d - Screen flickering
  • siedlik
    • Aug 2022
    • 11
    • United Kingdom
    I got the issue with an Alienware aw2721d, every 2-3 sec the screen is flickering/going black. I have tried to change the resolution and refresh rate, didnt help. Also unplugged the HDMI and the screen was still flickering. So I hope it's just a power supply issue.
    I have removed the boards to check for bad caps and something maybe unusual.
    I have checked the big cap - Lelon 450v 100uF and when I checked it, it shows 91uF. Is that in range ? When power supply connected, the cap goes to max 370 and discharges very quickly, is that good ?
    I have attached the image of the power supply.
    Looking at the Dell website, I have found a user manual, and it shows how to remove the cap from the board.
    Will do some more tests and will try to find something.
    Also, if I would replace that big cap, does it just have to be 450V and 100uF ? As I can't find the same one from Lelon.
    The cap 3 letters are RPL, but I can't see the tolerance for it.
  • dragos2009
    • Mar 2013
    • 110
    • Romania
    Re: Alienware aw2721d - Screen flickering
    man that monitor is fairly new and it should be still under warranty which could be sent back to dell you can check if it is still under it on dell's website using its service tag or serial number, i suggest cleaning all traces /residue of you opening it up and send it to dell
    • siedlik
      • Aug 2022
      • 11
      • United Kingdom
      Re: Alienware aw2721d - Screen flickering - Fixed
      I bought it from eBay, so don't know what they did.
      But after spending a few hours, reconnecting everything and a bit of cleaning, the monitor works now.
      1440p, 120fps and G Sync looks amazing. Waiting for display port cable to test 240hz.
      I was ready to replace caps and fuses
      • Ado02
        Lenovo Thinkpad X1 Gen 10 - Flickering Screen
        by Ado02
        We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the Intel® Iris® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
        The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
        12-16-2024, 02:33 PM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • kain0007
        Alienware X15R2 P111F black screen after updating windows.
        by kain0007
        Hi Masters.
        I have an Alienware x15R2 laptop that went black after updating Windows.
        Could someone help me repair my bin?
        Alienware X15R2
        ST: 1CJY6M3
        Thank you very much for your support....
        10-09-2025, 02:20 PM
      • jagiro84
        Alienware x15 r2 black screen
        by jagiro84
        Hi there I hope someone can help me with fixing this issiue
        ​​​​​​Symptoms
        My Alienware x15 r2 stopped working, which is around 2years old.
        ​​​​​​ power light and keyboard turns on, power lights give 2red and 3 blue lights,
        screen stays black
        From dell error codes it says this is error
        2,3 No memory or Random-Access Memory (RAM) detected
        after disassembling and removing battery removing any electricity left with power button on without psu connected,...
        11-25-2023, 03:44 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
