Samsung 225mw displays image for 2sec and go very dark
  • maateusjo
    • Jul 2022
    • Portugal
    I have a TV/Monitor Samsung SyncMaster 225MW 55,9 cm (22") 1680 x 1050 HD that shows image when turned ON but after 2 seconds the image gets very very dark.
    If you look at it in a certain angle with you will see that the picture is still there. This TV/Monitor has like 10+ years old so it can be many problems due the age, battery supply or due to Cap problems.
    Someone have any sugestion or help?
    Cheers,
    maateusjo.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Samsung 225mw displays image for 2sec and go very dark
    A more common name for this monitor is 225BW.
    You can search the forum for threads (select "search thread titles only" on the search page with this: 225*
    You will find many examples, you specific failure is called "2 seconds to black" in the repair industry.
    Here is one example (of many):
    https://www.badcaps.net/forum/showthread.php?t=31174
    And here is the big thread for this monitor:
    https://www.badcaps.net/forum/showthread.php?t=6930
    • maateusjo
      • Jul 2022
      • Portugal
      Thank you a lot, I'll check them out!
      Cheers,
      maateusjo
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        You're welcome, you can also read the sticky thread in this forum section, especially posts #19 and #20:
        A guide on how to troubleshoot 2 seconds to black.
          09-07-2024, 05:50 AM
        • fuxxy
          Samsung LN46A850 - Displays image that degrades, then reboots
          by fuxxy
          Samsung LN46A850. Purchased new like 150 years ago.
          This unit recently started doing this.
          Power the TV on, it powers up and displays picture. Picture will display fine for about 5-10 mins, then the image degrades with static-like horizontal lines until the set turns off, then the set will turn back on and the process repeats. When the horizontal static lines appear, they push and stretch the remaining image below the static off of the viewable portion of the screen.
          While this feels like potential bad caps, I don't have a clue where to focus my efforts....
          08-02-2022, 08:18 PM
          by momaka
          03-15-2023, 10:17 PM
        • shlomim412
          samsung ua55es6800 - no image
          by shlomim412
          hi
          having problem with samsung ua55es6800
          tv had backlight on, sound working - responds to the remote control but no image.
          check tcon board - had 12v in but no other voltages present.
          when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
          when leaving only left side connected - again no voltages and no image.
          put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
          kept trying to block less pins on the left ribbon cable...
          05-15-2024, 05:00 AM
        • 3D Modelka
          AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
          by 3D Modelka
          Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
          02-09-2024, 02:42 AM
