Dell 1905fp missing resistor
  • philosophe07
    • Jul 2010
    I'm working on a Dell 1905fp ultrasharp monitor's power supply.
    I was in the process of repairing it when a surface mount resistor from the solder side disappeared.... into the carpet/abyss.
    It's R134.
    I would appreciate some help in determining its value.
    Thanks ahead of time,
    =Teej
  • ecking767
    • Oct 2009
    • 492
    Re: Dell 1905fp missing resistor
    Hello r134 is 47K. I have this board on my work bench.
    ecking767
    • philosophe07
      • Jul 2010
      @ecking767
      Thank you much!
      Exactly what I needed.
      • jkleslie
        • Sep 2010
        I don't suppose you could tell me what resistor R125 is, could you? I'm having a terrible time finding it online and it is the last piece of the puzzle for this board.
        Thanks!
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • badcap111
          Xiaomi mi 9T missing resistor
          by badcap111
          Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
          I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
          Is...
          08-07-2023, 10:42 AM
        • spleenharvester
          Ugreen HDMI splitter missing a pulldown resistor
          by spleenharvester
          Odd one I've found. This splitter likes to cut out - on my Xbox Series S the display/audio would randomly go to black for a few seconds - on my PC the monitor would flicker several times before eventually staying on. A few others have reported similar issues. Couldn't be bothered returning it for the sake of £8.
          I pulled it apart and found it is driven by a Texas TS3DV642 mux/demux. There appears to be a missing pulldown resistor on the HPD line, it is just left floating. Adding a 100K pulldown to ground fixes the flickering.
          (Not that this is worth the hassle for an...
          09-15-2025, 11:23 AM
        • liquidzorch
          Missing resistor on BQ ILIM pin. DA0P5JMB6D0
          by liquidzorch
          Hello. I can't find the schematics anywhere for this motherboard, does anyone have one, and can give me the resistor value for the BQ728H missing in pic below? I already read the dadsheet, and this resistor value is calculated, so I can't just go with whats in the "typical" diagram.
          On a second note, could this resistor cause it to only boot with the battery and not the charger? It boots fine with a charged battery, but will not turn on with the charger (nor charge). The 19v does not get past the first mosfet, it recieves pulses to turn on, but something is preventing it....
          12-18-2023, 01:56 PM
