Blank Samsung SyncMaster 930B
  • djwestly
    • Jul 2022
    • 3
    System is a desktop running Windows 7 and am using 3 monitors (930B is not working).
    Seeing a blank screen even though display shows up in Windows 7 display settings.
    I can change resolution and refresh rate but screen remains blank.
    Device manager says display is working properly.
    NOT seeing any "no signal" message (even when computer is off) and it seems like mouse pointer can be moved onto the blank display (doesn't stop at edge of working monitor).
    Green (power?) light is blinking about 2 times a second constantly (even when computer is off).
    History:
    Monitor worked fine for a while.
    Then it started taking a while for my extended desktop to be displayed (only this monitor).
    The amount of time waiting for it to start working kept getting longer and longer until it stopped coming on at all (with system up all day).
    Took apart to look for bulging caps but they looked okay.
    Any ideas on what's wrong?
    Does it sound like a backlight problem or bad caps (even though they look okay)?
    Thanks,
    Dave
  • R_J
    • 9592
    Re: Blank Samsung SyncMaster 930B
    Do you have multimeter? Check the fuse F301 near D105 (may be under white silicon)
    • djwestly
      • Jul 2022
      • 3
      What am I looking for?
      I don't know a lot about electronics (have replace caps in monitors thanks to youtube though).
      • R_J
        • 9592
        there is a fuse that supplies voltage to the inverter section on the board, if it is open you will not have any backlights. If the fuse is open, one or two of the mosfets may be shorted
          09-07-2024, 05:50 AM
          by momaka
          03-15-2023, 10:17 PM
        • RetroComputingGrotto
          Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
          by RetroComputingGrotto
          I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
          I've uploaded a video of it happening on YouTube:
          I've taken the monitor...
          01-11-2024, 05:37 AM
          09-06-2024, 11:40 PM
