Samsung 2232bw recaped and still nothing
  • benobeno
    • Jun 2010
    • 25
    • Slovenia
    Re: Samsung 2232bw recaped and still nothing
    That is not good news. It's time to search for a service manual or schematic. I am afraid that the problem is the processor chip has died.
    PlainBill
    So its not just the 5V regulator?
    And what part is the processor chip? Is this still a easy and cheap fix?
    bye
    • PlainBill
      • Feb 2009
      • 7034
      bye
      A little background: Your monitor could be considered a special purpose computer. It takes signals from the VGA and DVI inputs and displays them on the LCD screen. It also checks the two lines from the front panel and interprets them to make changes. AND it switches certain things on and off - the backlight, the display panel, and the power led.
      All of this is done by the processor. I've circled it in the picture below.
      As far as replacing it, it's a custom Samsung chip, so it's unlikely you would find replacements available. And there are a lot of pins to solder.
      PlainBill
      • benobeno
        • Jun 2010
        • 25
        • Slovenia
        Hello
        I have one more question.
        So I am going to try to change the regulator and hope for the best, before I throw it away.
        Can you please tell me what kind of a regulator that is? I only know that it is 5V. What more info do I need, so that I can teel the dude in the shop to give me the right one.
        Bye
        • Agent24
          I see dead caps
          • Oct 2007
          • 4913
          • New Zealand
          Even if it doesn't work, you don't have to throw it away - you could sell it for parts!
          -David VanHorn
          • PlainBill
            • Feb 2009
            • 7034
            Hello
            Bye
            I seriously doubt that changing the 5V regulator will make a difference, but I won't even pretend that I'm infallible. I'd ask for an AP1501-50K5. It is a 150Khz, 3A PWM Buck DC/DC Converter in a TO263-5L package. As closely as I can tell, that is the original manufacturer. If your supplier doesn't carry Anachip Corp parts, there are a number of other manufacturers that produce parts that are identical.
            PlainBill
            • poly25
              • Sep 2010
              #26
              I have the same problem whith my samsung 2232BW the AP1501-50K whith HW2596-50c and I have the same problem - only blue led on no invertor start no display.
              Some solutions please.
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                1) Start with post clear focused pictures of your boards using the manage attachments function and please do not post inline.
                2) Do you have a multimeter?
                3) Hookup a working computer with your favourite wallpaper to the lcd. If you shine a flashlight on the lcd, do you see the wallpaper?
                --- begin sig file ---
                --- end sig file ---
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4913
                  • New Zealand
                  #28
                  I suggest he start his own thread. Posting in other threads just makes everything harder to follow.
                  -David VanHorn
                  • benobeno
                    • Jun 2010
                    • 25
                    • Slovenia
                    #29
                    Hello
                    It is some time ago since we have last talked about my samsung LCD , but no I have aquired a working signal board and the LCD is almost working perfectly, but...
                    Ok the situation is like this: when i turn the LCD on the picture shows for about a second or two and then the ccfl goes off, but the picture is still there in the dark.
                    But if the situation (red multimeter lead on the marked pin and the black lead on grounf bolt) is like on the picture attached the LCD is working normal. And it also works if only the red lead si touching the pin.
                    Can somebody tell me why is that so and what to do?
                    Bye
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #30
                      I wouldnt "play" on that pin - could be 2000-3000 volts!!!!!!
                      Try resoldering it and all the joints on route to the lamp socket.
                      With the power off you could test the secondary resistance on each of the two transformers - should be within 3% .
                        You should make two test lamps to verify if you do have inverter problem or lamp problem:
                        https://www.badcaps.net/forum/showth...er+testing+cfl
                        Did you check the resistance of the high voltage winding of both transformer yet, check the power MOSFETs?
                        • benobeno
                          • Jun 2010
                          • 25
                          • Slovenia
                          #32
                          Hello
                          The resistance is 1.187 in the 2k mode, is that ok? The lamps are both working if i make the connection with a multimeter as described in the previous post.
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #33
                            Is that the resistance on BOTH transformers. Are any of your blue high voltage
                            caps in that area discoloured?
                            • benobeno
                              • Jun 2010
                              • 25
                              • Slovenia
                              #34
                              One has 1.187 an other 1.184. Both blue caps are blue as they should be.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #35
                                Well they look ok - I dont know enough about circuits to comment further -
                                Could try tracing where the circuit goes from that blue cap and see if resistance differs
                                from the same tracing from the other transformer.
                                Could try swapping the lamp leads over if they are long enough and despite me saying dont play in that area , if you are courageous enough test to see if the problem moves.
                                Perhaps budm will come back with an idea.
                                  Resistance are OK.
                                  There are two Power MOSFETs 8-pin SMD in that inverter section. Can you get the P/N as printed on top so we can look for the pin out? We need to check the resustance between S pin and the D pin of those two MOSFETs.
                                  • benobeno
                                    • Jun 2010
                                    • 25
                                    • Slovenia
                                    #37
                                    stm8309
                                    75h71
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4913
                                      • New Zealand
                                      #38
                                      stm8309
                                      75h71
                                      Here's the datasheet
                                      -David VanHorn
                                      • benobeno
                                        • Jun 2010
                                        • 25
                                        • Slovenia
                                        #39
                                        If i measured it corect there is no resistance between s and d pins.
                                          OK then, next thing to do is to use test lamps otherwise you can be spending lots of time trying to narrow down where the problem is.
                                          BTW, the DC voltage (around 16~19VDC) on cap C111 is always present, right?
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
