Westinghouse L2410NM Power supply?
  • firefighterfox
    • Dec 2015
    • 21
    The symptoms are dead set. After looking into the circuits, there are 3 modules. A power supply, main board and a video board. I may or may not be using the right terms. The power supply is obvious. The board that all the LED strips attach to, I'm calling a video board. With the unit plugged into 110 vac and the video and main boards unplugged, I have 3 voltages coming from the power supply. 5vdc, 14vdc, 24vdc
    When I plug the two boards into the power supply, all 3 of those power supply voltages drop significantly. I have no schematic on this unit and the boards are not labeled as to where B+ voltages are located. I have replaced the 4 electrolytic caps that are on the video board.(2 looked slightly bulged at the top) I have not changed any caps on the power supply. I'm looking for further diagnostic steps to confirm why and where I'm loosing my voltages?
    Thanks for any help/ suggestions.
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Westinghouse L2410NM Power supply?
    You might go to this link for LCD and Monitor basic troubleshoot guide
    https://www.badcaps.net/forum/showth...ight=tv+repair
    So the above is the current page. The thread on the first page by BudM has the guide.
    This is the link to the first page
    https://www.badcaps.net/forum/showth...repair&page=23
    • R_J
      • Jun 2012
      • 9588
      Do the voltages on the power supply stay up if you just disconnect the inverter board?
      Post pictures of your boards.
