Dell U27173HMt 27 inch screen flickering and lines
  • pronester
    • Oct 2019
    • 49
    • Malaysia
    Hello guys,
    I got a faulty Dell monitor with LCD Panel LM270WQ1. The picture flickers, got lines and blur as u can see in the attachments.
    No burn marks especially on the motherboard, tcon board and power board (of course since the monitor can be turned on).
    I have checked some voltages from the tcon board as below:
    VGH 19.5v
    VGL -5.92v
    From the cof board:
    VCOM-R 5.4v
    VCOM-R -5.4v
    If anyone of you have encounter the issue as titled above and manage get it fixed feel free to share tips and tricks. I think the lcd itself is shorted to ground but any workaround to get it work again?
    Many thanks.
    • Jul 2011
    • 6069
    Re: Dell U27173HMt 27 inch screen flickering and lines
    To me it looks like the LED light bulbs are failing either because of age or are being over driving them because of the color of the screen
    Also I see some of LEDs brighter than others which makes me come to this conclusion I could be completely wrong but when I have over driven white LEDs like that I have seen them change colors like this
    Try this go to setup in the monitor and lower the brightness to the point that you can almost not be able to see the screen anymore and see if the color of the LEDs change if it does then this is probably your problem
    I googled the device number U2713HMt” and it does have LEDs for the back lights “
    I can not tell you anything about the lines on the screen unless you have bad capacitors on the switching power supply section of the board
    I hope this helps
    • pronester
      • Oct 2019
      • 49
      • Malaysia
      I hope this helps
      hey sam, thanks for the heads up..i think better if look at the LED lights as u suggested. thanks again.
      • atunguyd
        • Oct 2018
        • 8
        • South Africa
        @pronester did you have any luck yet? I have a 2717 that intermittently does this, it will have a similar display and also emit a hissing type sound. Pressing the front power button off and then back on typically resolves it (sometime s few time) so I suspect that something is on its way out.
        • pronester
          • Oct 2019
          • 49
          • Malaysia
          hi atunguyd..sorry for the late reply..nope..i havent sort it out yet..most probably the panel is shorted to ground
          as for your situation i think might be the power board/supply issue
          • HTR-Informatique
            by HTR-Informatique
            02-09-2025, 06:51 AM
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • Swedishpower
            Dell G3 15 3500 black screen
            by Swedishpower
            Hello
            I have search everywhere for a solution for my problem, but cant find it anywhere.
            When I was away to trow some garbage i always look in the electronic bin.
            and this time i find a laptop.
            Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
            the lamp for charmig is white.
            Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
            but no Dell logo.
            I tryed with a hdmi cable to another screen, still black.
            I started to search solution and tryed...
            07-06-2025, 06:18 AM
          • Ado02
            Lenovo Thinkpad X1 Gen 10 - Flickering Screen
            by Ado02
            We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the Intel® Iris® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
            The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
            12-16-2024, 02:33 PM
          • Guybrush
            Dell U3419W horizontal lines and flickering
            by Guybrush
            After watching too many electronics repair videos (but not monitors) I came across a dell monitor with flickering horizontal lines. I haven't purchased it yet so don't have much info, but from the video and pic do you think there is a chance of repair or is just simple panel damage?
            Seller claims; "but due to sun damage has some grey lines going through it"
            https://i.imgur.com/VpTcZFn.mp4
            Chris...
            10-23-2023, 06:17 PM
