EMAX monitor overheating?
+ More Options
Posts
  • ndoggfromhell
    • May 2010
    • 24
    Got an emax monitor that seems to overheat. I'll turn it on and it will work for a while, then it will go blank. I'll leave it off for 15 minutes and it will start working again after it's cooled down.
    I've taken it apart and everything looks ok. no visably popped caps on either board. Since it's a heat issue, i'm thinking it's one of the mosfets possibly? Any ideas on how to proceed?
  • PlainBill
    • Feb 2009
    • 7034
    Re: EMAX monitor overheating?
    The unhelpful comment: Use the classic troubleshooting approach. Find the bad part, replace it.
    Trying to be helpful; it's unlikely that it is a mosfet. It is much more likely that the problem is on the logic card. I would suspect the processor, but it could also be one of the voltage regulators.
    The classic approach to identifying the problem - hot and cold. Use a hair dryer or heat gun to see if heating a component will speed up the failure. Use freeze spray to see if cooling a component will delay the failure.
    PlainBill
      by momaka
      03-15-2023, 10:17 PM
    • ant3202
      HP 27es - LED monitor - Monitor Flashing On - Off
      by ant3202
      Hi Everyone
      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
      https://www.badcaps.net/forum/troubl...lashing-on-off
      The monitor is HP 27es LED Monitor
      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
      The monitor will randomly blackout and display no signal and will recover again.
      Sometimes need to power and off again to restore the display but...
      03-20-2025, 07:30 PM
    • Rick_1234
      by Rick_1234
      Good evening, gentlemen.
      Things I tried
      06-22-2024, 04:44 PM
      Wise Wing F199 19'' LCD monitor - recapped
      by momaka
      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
      When I saw the Craigslist post, I wasn't...
      08-24-2020, 10:58 AM
    • sew333
      Pc shutdown, monitor flickered with no signal after 10 seconds
      by sew333
      My pc:
      10850K stock 4800mhz stock Kraken X73 good temps
      2x16 GB DDR4 GSKILL 3000mhz XMP
      Seasonic Tx-850 Ultra Titanium
      Gigabyte Rtx 3090 Gaming OC
      Aorus Z490 Pro Gaming
      1 TB SSD
      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
      Power...
      02-22-2022, 10:27 AM
