AOC Q3279VWF, distorded image
  • Sraros
    • Jan 2017
    • 223
    • Greece
    I open another thread as the title to original is now misleading.
    https://www.badcaps.net/forum/showthread.php?t=92372
    So I originally received this monitor without power and after finding that the main board was burnt damaged (probably by lightning) in VGA and HDMI ports I replaced it and now I do have picture but distorted as in pictures attached.
    I took some voltage measurements on the TCON board and they are:
    VIN: 12.75V when ribbon cables of panel are connected. 11.75V when disconnected
    VGH: 29.7V
    VGL: -7.3V
    VCOM: 6.3V
    AVDD: 15.63v (15.83V when disconnected)
    VDD: going up to 3.25V then dropping to 0 and back again in a loop. This happens with or without the ribbon cables of the panel connected.
    I am wondering if there's another problem with the main board I received, the TCON board or the panel, although I doubt it's the panel since VDD fluctuates even without the panel connected.
  • Sraros
    • Jan 2017
    • 223
    • Greece
    Re: AOC Q3279VWF, distorded image
    While the monitor is on I checked with my finger and found out IC301 in red circle is getting fast too hot so I guess it's shorted. The thing is I cannot find anything by searching iML 8940. If this the DC-DC converter can I change with another one maybe?
    • lotas
      • Jan 2016
      • 4883
      • Russia
      Display ASSP Family
      Here the replacement will not work, it is programmed and controlled by the I2C bus. If the problem is in it, then you need to look for a donor with a broken matrix and transplant this chip. But maybe the problem is not in it, but in the ceramic capacitors at the outputs or in the panel itself.
      I didn’t notice that this chip is on the T-CON board, I thought on the bar of the matrix itself, then you need to look for the same T-CON and from the same matrix.
      • Sraros
        • Jan 2017
        • 223
        • Greece
        With both original T-Con and replacement it does the same thing.
        Its funny that the image is “somehow correct”, it just doesnt interpolate right.
        It's like every odd number of pixel columns is displayed correctly and every even number of pixel columns is moved like a clone of the display.
        In the link there's a video I took of how it shows stuff on screen.
        https://we.tl/t-FRJEmqvbxp
        • rimwall
          Sony KD-65x7500D - double image - Tcon or Panel?
          by rimwall
          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
          11-18-2025, 02:09 AM
        • netgearnetgear
          TCL 43S423 TCON OR PANEL FAULTY???
          by netgearnetgear
          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
          08-20-2025, 06:04 PM
        • stylishconsultant
          un60j620dafxza - Samsung No Display Problem
          by stylishconsultant
          Hi All,
          Need help.
          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
          09-04-2024, 03:26 AM
        • MDY94
          Hitachi 50HK6100U display issue
          by MDY94
          I own a Hitachi 50HK6100U with a display fault. After some troubleshooting, I've found that removing one tcon cable produces a clear image on the side still connected. Removing the other tcon still provides display output; however, this is a heavily distorted image. With both cables connected, only the top ~25% of the screen provides display output which is still distorted. It's only when both are connected that most of the screen no longer provides output. The attached images show the screen with each tcon cable disconnected, and one with both connected. The red line shows where the display cuts...
          12-18-2024, 12:31 PM
        • mmartell
          General Questions on the Relationship Between Mainboard, TCON and Panel
          by mmartell
          My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
          I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
          And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
          01-06-2024, 01:32 PM
