AOC Q3279VWF, no power
  • Sraros
    • Jan 2017
    • 223
    • Greece
    I have this monitor that doesn't power up. I hear a tiny clicking sound which indicates a short. I run a quick visual test and found on the mainboard right before the VGA and HDMI outputs these burnt components as attached in the pictures.
    What could cause such a thing and should I go for a repair?
  • lotas
    • Jan 2016
    • 4865
    • Russia
    Re: AOC Q3279VWF, no power
    This could happen if the hdmi cable was connected "hot" or due to lightning.
    • Sraros
      • Jan 2017
      • 223
      • Greece
      Maybe lightning more possible since both VGA and HDMI have burnt components right before output?
      If I desolder these should I expect to power up or maybe the monitor is completely damaged?
      The power board seems intact all fuses are good
      • lotas
        • Jan 2016
        • 4865
        • Russia
        In such cases, the scaler (microcontroller) usually burns out.
        • R_J
          • Jun 2012
          • 9624
          The parts on the hdmi line are for protection on the data lines, they can be removed for testing, the data lines should be straight through under the udfn-10 (DFN2510-10)esd protector. Like mentioned above, there is likely a lot more that is bad.
          If you do have it working a possible replacement part would be a PESD1LVDS by Nexperia
          • Sraros
            • Jan 2017
            • 223
            • Greece
            Hello, returning on this thread.
            I finally received a replacement mainboard.
            The monitor now opens, meaning there’s standby voltage.
            Also if i hit the power button it turns on but there’s nothing on the screen. With flashlight test there’s nothing showing.
            When I connect the HDMI cable it also opens automatically but there’s no sound from windows (like there’s a new device connected)
            The backlights work for sure.
            Does this mean I also need an inverter board?
            • Sraros
              • Jan 2017
              • 223
              • Greece
              Attached a photo of the T-con.
              The fuse F301 is ok but the little smd zener diode Z301 is shorted.
              I went through the inverter boards and the rest of T-CON and didnt find any other short.
              • lotas
                • Jan 2016
                • 4865
                • Russia
                Z301 is not a zener diode, it is a pass-through, interference suppression capacitor, there should be no short circuit between 1.2 and 4 pin.
                • Sraros
                  • Jan 2017
                  • 223
                  • Greece
                  Ok.
                  1-2 shorted
                  3-4 shorted
                  Not between them though
                  • Sraros
                    • Jan 2017
                    • 223
                    • Greece
                    The last test I did was to remove the ribbon cables one by one to the inverter boards. When I removed the left ribbon nothing changed. When I removed the right ribbon there was white on the right when the logo of AOC should flash on screen.
                    • Sraros
                      • Jan 2017
                      • 223
                      • Greece
                      Coming back quite some time later on this. So I picked up from where I left this monitor.
                      I cleaned the ribbon cables from the T-con to the panel boards and I have image now but is way off! The logo is displayed like in photo attached, split. The image is terrible and flickering noise sound from the boards. Any suggestions?
                      • Sraros
                        • Jan 2017
                        • 223
                        • Greece
                        VIN: 12.75V
                        VGH: 29.7V
                        VGL: -7.3V
                        VCOM: 6.3V
                        VDD: going up to 3.25V then dropping to 0 on and on.
                        Voltages remain the same with or without the ribbon cables connected
                        Is it safe assumption it is the T-con board at fault if the VDD comes and goes with and without the ribbon cables connected on the panel boards?
                        • Sraros
                          • Jan 2017
                          • 223
                          • Greece
                          I changed the T-con board with another good working one from a same monitor with broken panel but nothing. Same results
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                          • mikey5791
                            Philips 196V3L monitor power led off
                            by mikey5791
                            Hi, i was given this lcd monitor last week with the issue of power led blinking. Upon checking the power board, i found 2 pieces electrolytic caps bulged and replaced them.
                            Later, when i switched on ac power and detected 5v and 15v dc at output pins. But as soon as i pressed on the front power button, the led on power button lights for 1 second and it turns off.
                            So, i tried disconnect the flex ribbon cable from t con board. But all i got is a white screen with nothing on. I suspect there is something short somewhere that prevent the display being turned on. Can someone with...
                            01-25-2024, 07:52 PM
