Hansol H950
  • davg
    • Sep 2008
    • 536
    Hansol H950
    Hi I just replaced the lamps in this unite and it worked fine. Afte unpluging it from AC and pluging it back in I get these vertical lines on the screen. If I leave it awhile powered on and switch it off and on it showes my desktop ok? Go figure. Any suggestions anyone
  • PlainBill
    • Feb 2009
    • 7034
    Re: Hansol H950
    Try reseating the connectors from the logic card to the panel.
    PlainBill
    • davg
      • Sep 2008
      • 536
      Re: Hansol H950
      PlainBill
      Thanks PlainBill tried re-seating the connectors to the logic card the issue still exist? I did replace the caps in that area It looks like i damaged the trace on the one circled in red would this cause it? can a trace be repaired?
      • PlainBill
        • Feb 2009
        • 7034
        Re: Hansol H950
        That's probably not the cause.
        Any broken trace can be repaired by scraping off the coating then soldering a short piece of wire across the break.
        PlainBill
        • retiredcaps
          • Apr 2010
          • 9271
          Re: Hansol H950
          Check the solder joints at upper left and lower right at T1. The lower right looks like a ring crack? Or it could be the lighting?
          Upper left on L51 also looks suspect?
          --- begin sig file ---
          --- end sig file ---
          • davg
            • Sep 2008
            • 536
            Re: Hansol H950
            Thanks retiredcaps I re-soldered these points still no change? As I indicated earlier if left powered up the thing works but the screen is rather bright but if I do a factory default it seem to be just fine. I did notice however that when connected to the Dvi output it does not work???
            • davg
              • Sep 2008
              • 536
              Re: Hansol H950
              This unit is still giving the same problem. When first turned on I get these lines but it seem that after it warms up I get a picture and if it is left on it seems to work ok but if it is allowed to go into standby the symptoms start again?? I have reset the connections and done some re soldering. Any ideas what to do next?
              • PlainBill
                • Feb 2009
                • 7034
                Re: Hansol H950
                This sounds more like a logic card problem than a power supply problem. Check power supply voltages both when it's working and when it's not. If essentially the same, start looking at regulators on the logic card.
                PlainBill
                • seanc
                  • Nov 2008
                  • 1319
                  Re: Hansol H950
                  I had this issue on a Proview monitor when the PSU caps were bad, it powered up nice and bright but displayed lots of pretty lines. New caps solved the problem.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Re: Hansol H950
                    Hmm, when I had the Hansol H711 here, it wouldn't power on and that was because of a bad cap in the PSU.
                    A search for H950 in the image section seems to show that the PSU is in the base just like the H711.
                    It might be worth checking out? It was a bugger to take apart, but you can see what it looks like from
                    https://www.badcaps.net/forum/showth...ghlight=hansol
                    • b4rdock
                      HP Elite Dragonfly 13.5" Chromebook locked
                      by b4rdock
                      i have a case with this chromebook locked i try the method change the line see example picture, but afte reprogram the bios not give me video any help for unlock this
                      sku_number 6M5X6UC-ACH
                      serial_number
                      5CD303487P​...
                      02-15-2025, 09:43 AM
                    • Abdulrhman Alabsi
                      Dell precision 7530 blue screen
                      by Abdulrhman Alabsi
                      I have problem in my laptop, When I try to enter to windows it showes me blue screen, I changed hard driver and ram but it did the samthing...please give me the solution of it
                      02-09-2025, 10:39 AM
                    • tesnic
                      Lenovo yoga 3 14 - nm a381 -3V problem
                      by tesnic
                      Hi guys! Thanks in advance to your help. I have a Lenovo yoga 3 14 (mainboard NM-A381). The actual issue, aftter change the shorted KBC, is the impossible to have the 3V. The BQ seems OK (i have 20V, regn, but not the AC_OK (1V only), it was replaced likewise. I replace 3 o 4 times the PU201 (it's very very hot afte connecting the charger) but i dont be able to work properly. All the replacements of these chip are get very hot.. Is possible the replacements of Aliexpress are spoiled, i order new ones from other seller.... But what could be the fault? What measurings can do?
                      Link to...
                      11-12-2024, 02:58 AM
                    • Rulycat
                      "Magna" 300W ATX PSU (bad workmanship inside)
                      by Rulycat
                      Here is a Magna 300W ATX PSU, with plenty of bloated JEE and other caps:
                      Primaries are HEC 330uf 200V (will change these when I get some other caps)
                      Now I said on the other thread about the electronic clock kit I was waiting on some caps off my dad. Well here they are in action! and before I get roasted for bad repair work or it's dangerous etc, this is just a "Will it work?" project, using what I now have, which is Jamicon 85C caps, Fake Nichicons and Fake Panasonic FR caps!
                      At least the values are a lot larger.
                      The 470uf...
                      10-14-2018, 10:33 AM
                    • davg
                      Hansol H950
                      by davg
                      This monitor is giving me some grief. When I turn it on it gives a bunch of pretty lines. (Photo #1) When I turn it of and back on I get lines as in photo 2 and after it warms up and I turn it off and on it works perfectly. (Photo 3). If it goes into sleep mode for any length of time the symptoms start all over again? Leave it on, attached to a continuous signal, it will work without fault. I have run it for days. I have had it apart. Replace the caps checked all connections several times. It did have bad ccfl lamps which I replaced. Anyone have a similar experience? I posted on this way back...
                      11-16-2012, 10:55 AM
