Another Dell with backlight/inverter probs
  • bob12345
    • Apr 2010
    • 31
    My other Dell monitor a 1704FPTt is also faulty, when I connect it to the mains and press the power on button, everything operates as normal - power light turns green, Dell logo appears, but the backlight will light up then go out after a second or two. The desktop/standard no signal image can be seen if I shine a light at the panel.
    Tests so far:
    Swapped the panel + ccfls with another but same occurs. Tried only connecting 1 ccfl plug (out of the 4) at a time, but neither has worked.
    Replacements so far:
    Suspected from reading on here that the 4 inverter transistors were dead or at least one was playing up so replaced all of them (AOU402) with new ones.
    Tested again same problem occurs.
    Replaced the inverter IC - OZ9930G on the track side of the power PCB with another new one. Still no luck
    All capacitors look to be in fine condition with no leaks or bulges. Could this be a transformer problem - I hope not as that probably means a junked board!
    Anyone got any ideas?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Another Dell with backlight/inverter probs
    Tests so far:
    Classic 'two seconds to black' problem. It could be a transformer, or it could be something else. I'll gladly walk you through the troubleshooting steps, but would appreciate a better (larger) picture of the back side of the inverter.
    PlainBill
    • bob12345
      • Apr 2010
      • 31
      Thanks Bill,
      Attached is a better pic - let me know if its ok.
      Note that at Q106 - the transistor at the top right of the cluster, the solder from its bottom leg got stuck to another square pad directly below it, but i figured the tracks were connected together anyways so no big deal... hopefully!
      • HTR-Informatique
        by HTR-Informatique
        02-09-2025, 06:51 AM
      • DanPoka
        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
        by DanPoka
        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
        02-15-2025, 05:05 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • miosz
        Dell Inspiron 15 3558 - no backlight
        by miosz
        I'm trying to fix friend's Dell, it had liquid damage in the past, but as far as I know it was fixed in professional service. It was working fine for quite some time, except for dead battery, but recently there was blackout in the building and after power was restored, laptop was broken. When I got it, it was posting, but OS didn't boot, also backlight was gone. After some tinkering I switched off secureboot and it started booting normally, but backlight issue persisted. I opened it up and started looking for issues. Checked both fuses on display and all fuses on motherboard which I...
        03-12-2024, 07:21 AM
