LG 24MP56HQ-P Monitor Backlight problem?
  • tmhobadcap
    • Apr 2019
    • 156
    • CANADA
    I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
    Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
    I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip. I tested all leds individually and in groups (they are divided into 3 groups) and they all can be lighted up. I have also tested all the connections and they are also good.
    There are six wires connecting from the mainboard to the led strips. With the blue (edited) wire as the first wire, I found the 3rd and the 4th with 19V and all other with 0V. From the connector of the led strip, I found the 3rd and the 4th wires are connected and connect to one end of each of the three groups of leds. The 1st, 2nd and 6th wires are connected to the other ends of the three groups of leds. The 5th wire just has no connection to the leds. One group of led has 16 leds and so 19V is not high enough to light up the group.
    Is this a backlight problem? According to the trouble shooting section of the manual, if no image is shown on the screen, we should check the brightness and contrast. But when I press the menu button, I could not get the menu on screen to check the brightness and contract, nor to go to reset.
    Can somebody please help me to fix this monitor?
  • tmhobadcap
    by tmhobadcap
    I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
    10-12-2021, 01:43 PM
  • Askic
    Problem with monitor DS-D5022QE-B
    by Askic
    Hello to all,
    I have a problem with monitor that is delivered together with CCTV system.
    The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
    I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
    05-31-2023, 03:14 AM
  • shlomim412
    tcl tv - 65c815 problem - bad leds?
    by shlomim412
    hello
    can you please say if this is a problem with weak\burned leds?
    if yes, can you please if in this model the panel is glued to the frame?
    thanks!...
    08-23-2025, 02:43 PM
  • CptChronic
    Samsung LU32J590UQUXEN Monitor display problem
    by CptChronic
    I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
    Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
    But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
    04-24-2023, 04:33 PM
  • Phil Stasik
    Pioneer PRO-FHD1 Elite Plasma Monitor Start-Up Problem
    by Phil Stasik
    Pioneer Pro-FHD1 Elite. Failure to power on.
    I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
    We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the...
    01-19-2023, 01:22 AM
