1504fp no power despite new MOSFET
  • kturnerga
    • Apr 2010
    • 20
    Hi!
    I replaced a MOSFET on a Dell 1504FP power supply (everyone has one or knows someone who has a 1504FP that doesn't cut on . It still won't power on or indicate it is getting juice. I am about ready to recap but the caps aren't swollen or even bulging. I also noticed that the inverter board (board in upper corner w/ 2 two-pin plugs) is covered in some sort of coffee-like spooge. If the power supply still functions would the coffee-laden board still preclude a power-on LED?
    Sadly I'm not privy to anything other than a digital voltmeter but I do have another 1504fp sans power supply. If this fails I plan to get my paws on an HP that does the two-second tango with the power.
    Thanks. You fellas do good work for us board-swappers/admins out there in geekland.
  • PlainBill
    • Feb 2009
    • 7034
    Re: 1504fp no power despite new MOSFET
    Originally posted by kturnerga
    Hi!
    The first step is to measure the output voltage of the power supply. In general terms, there are two acceptable methods of troubleshooting.
    The first I like to call 'Divide and Conquer'. It involves testing at points chosen so as to eliminate large portions of the circuit. (If the power supply is putting out 5V and 12V there is no point in checking the line cord or the power fuse).
    The second is called 'Walking through the circuit'. This would involve checking the outlet, verifying line voltage is present at the diode bridge, measuring the voltage across the filter cap, etc.
    Notice that neither of these involve blindly replacing parts because 'they might be bad.'
    PlainBill
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
    • CMCM
      Russound CA4 Power Supply Repair
      by CMCM
      Hello Everybody,
      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
      The outputs marked 12v and 20v are all measuring only 1v.
      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
      The capacitors physically look clean (no bludgesor leaks) and...
      07-03-2025, 01:12 PM
