Westinghouse TW-80001-S024A Flashing red power led
  • PlainBill
    • Feb 2009
    • 7034
    Re: Westinghouse TW-80001-S024A Flashing red power led
    Originally posted by matyy
    Hello to all, i am a new member here.
    MY Westinghouse TW-80001-S024A AFTER I REPLACE THE INVERTER NO DISPLAY
    BUT THE bakelite IS OK
    CAN ENY BODY TEL MY WHAT TO DO ?
    SORRY FOR MY BAD ENGLISH
    Without more information, it's hard to offer meaningful advice. One possible cause: The cable from the signal card is not connected to the LCD panel.
    A picture of the back of the monitor showing all the cards would help. Attach it using 'Manage Attachments' - below the text entry area. Also include a description of the original problem.
    PlainBill
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • STKR123
      Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
      by STKR123
      As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
      I wonder if re-flashing the BIOS might be of any use here.
      As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
      There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
      11-03-2024, 06:58 AM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Thomas Smith
      Asus Tuf gaming fx506l no power, mosfet does not open
      by Thomas Smith
      Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
      Initial Symptoms:
      • The laptop has no power at all (no LEDs, no fan spin).
      • No 3.3V or 5V present on the board.
      • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
      Power Rail Checks:
      1. Charger input (FETs PKCH2BB)
        • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
      2. BQ24780S Charger IC:
        • VCC and ACDET are present.
        • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
        • Shunt resistor has 10Ω to ground.
      03-30-2025, 03:38 AM
