Dell 3008WFP Monitor Intermittent Text Shadowing
  • spike3333
    • Jan 2014
    • 43
    I have a Dell 3008WFP that has an intermittent problem where text appears to have a red and blue shadow on either side. It doesn't happen all the time, probably once a week. I can clear it by turning the monitor off and on. I don't have any images to post, I'm hoping it's a common problem that forum users are familiar with.
    Is there a PCB or component I can replace to fix it? Is there an online service manual for this monitor?
    Thanks,
    Spike3333
  • boyebaran
    • Sep 2015
    • 249
    • iran
    Re: Dell 3008WFP Monitor Intermittent Text Shadowing
    hi
    first open monitor and check for cold solder and check all electrolyte cap.
    also You can heat the PCB with a hair dryer and see if the heating has an effect.
    • spike3333
      • Jan 2014
      • 43
      Thanks I'll try that. Do you know which PCB controls aligning the colors?
      • boyebaran
        • Sep 2015
        • 249
        • iran
        main board and T-con board(pcb on the display)
        have you try another cable signal?
        please share a picture of problem
        • spike3333
          • Jan 2014
          • 43
          The problem just happened again this morning. Here are pictures of the screen with the problem and after I turn it off and then on again.
          • boyebaran
            • Sep 2015
            • 249
            • iran
            Did you do all that said?
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Remove LVDS cable between mainboard and Tcon, spray contact cleaner, plug it back in and give it a bit of a wiggle. Should fix your problem.
              A working TV? How boring!
              • spike3333
                • Jan 2014
                • 43
                OK thanks. I reassemble the monitor and now it is stuck in burn in mode with the primary colors cycling on the screen.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  There was a sequence to kick it out of that mode, should be in the service manual, it's the same for many Dell monitors.
                  • spike3333
                    • Jan 2014
                    • 43
                    Thanks, I tried all the reset sequences recommended by Dell and none of them worked. Someone else said this could also be caused by a bad cable and/or connector at the T-Con. Is there any way to trouble shoot this with out replacing two PCBs (T-Con and Main) and a cable?
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Just replace the cable first, it's the most likely to fail.
                      • spike3333
                        • Jan 2014
                        • 43
                        OK, will do. Thanks again
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Also make sure you plug the cable all the way in and that all the pins of the ribbon are visible before plugging it in... Sometimes the ribbon slides out of the end connectors and thus becomes physically unplugged even with the connectors all the way in.
                          • spike3333
                            • Jan 2014
                            • 43
                            I reopened the case and removed the T-Con to Main PCB cable. It is definitely the problem. The wire coating is turning to powder and coming off allowing adjacent wires to short. Is there any way to get a replacement?
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Ouch. Looks like the cable equivalent of the infamous brown glue. Check ebay. If you can't find it there, I'm sad to announce you're gonna have to stitch it together yourself. Not the hardest thing to do but definitely tedious and time-consuming. Will probably lead to a few new grey hairs.
                                by momaka
                                03-15-2023, 10:17 PM
                              • JohnNovak
                                Samsung CRT TV letters or text is shadowing
                                by JohnNovak
                                Hi.
                                I have some problem with old CRT TV Samsung model: CW-29Z338T, 29" size TV.
                                The problem is that letters and other text are not clear, text or letters are shadowed on the right side.
                                I found 2 capacitors on CRT Picture Tube Board.
                                47uF/400V was leaking very bad, the second cap 10uF/250V was bad ESR reading so i replace this cap also.
                                Replacement these 2 capacitors did not help nothing.
                                I try to reduce brightness, contrast and sharpness. There is very small effect on this shadow.
                                To reduce G2 down have more effect...
                                11-21-2024, 09:52 AM
                              • wattage
                                AOC AG493UCX 49-inch monitor - Firmware request
                                by wattage
                                Hello Badcaps Community,
                                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                07-13-2025, 04:41 PM
                              • ant3202
                                HP 27es - LED monitor - Monitor Flashing On - Off
                                by ant3202
                                Hi Everyone
                                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                https://www.badcaps.net/forum/troubl...lashing-on-off
                                The monitor is HP 27es LED Monitor
                                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                The monitor will randomly blackout and display no signal and will recover again.
                                Sometimes need to power and off again to restore the display but...
                                03-20-2025, 07:30 PM
                              • Rick_1234
                                LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                by Rick_1234
                                Good evening, gentlemen.
                                I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                Things I tried
                                - Bought a new AC adapter thinking that was the problem but the problem...
                                06-22-2024, 04:44 PM
