Gateway FPD1530 works for a second then dark
  • rokkaholik
    • Jul 2010
    • 21
    Re: Gateway FPD1530 works for a second then dark
    Sorry, just got back from a trip
    • PlainBill
      • Feb 2009
      • 7034
      Read this: https://www.badcaps.net/forum/showthread.php?t=1868
      Then properly post a picture of the bottom of the board. I suspect you have a totally different monitor.
      PlainBill
      • rokkaholik
        • Jul 2010
        • 21
        The monitor is indeed a Gateway FPD1530
        • rokkaholik
          • Jul 2010
          • 21
          I'm not sure why, but the back board pic isn't working
          • retiredcaps
            • Apr 2010
            • 9271
            I believe the picture limit size is 2000x2000. You can crop out your carpet in the pictures to lower the size.
            In addition, the owner of this forum has been making changes in the last 3 or 4 days, but has not posted a notice that I'm aware of, and the site has been up/down lately.
            --- begin sig file ---
            --- end sig file ---
            • el3ctroded
              • Nov 2008
              • 198
              1) DMM in diode test: Test diodes D15, D16, D12, D8, D14 both directions and post results
              2) better pic of bottom. Take clear closeup of the entire right half of the board (side with discoloration). And I'd prefer they not be posted inline, just attached with the thumbnail...
              • rokkaholik
                • Jul 2010
                • 21
                #27
                I did crop the pics down to a 1200x800. I thought the board would automatically resize them to a small size and make them clickable to a larger size.
                • rokkaholik
                  • Jul 2010
                  • 21
                  #28
                  Here's a closeup of the discolored side of the board.
                  • rokkaholik
                    • Jul 2010
                    • 21
                    #29
                    OK... I see how it's done now. I thought I had to add the image from the attached files to the text area with the IMG tags or they wouldn't show
                    • el3ctroded
                      • Nov 2008
                      • 198
                      What are those diode readings I asked for?
                      Note: To get clear pictures, you need to do the following:
                      1) Put the camera in Macro mode (Usually identified by a flower)
                      2) Turn off the flash
                      3) Use sunlight for light source
                      4) Take picture directly above board, not at an angle
                      If it's still blury, use a tripod or steady you hands against something firm.
                      • rokkaholik
                        • Jul 2010
                        • 21
                        #31
                        I don't have any knowledge of how to test things or what readings go with what. I don't have anything to test with either. I mainly was asking what the two 1Uf caps mcfischer was referring to when I first posted in this thread.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          The 1uf caps in the first post are at location C106 and the one just left of it (just above ZD101).
                          • rokkaholik
                            • Jul 2010
                            • 21
                            #33
                            I can't find anything that resembles the 2 you mentioned. I must be blind
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #34
                              Look at the picture in the very first post. It near the very top in the middle right by the Delta.
                              That is why PlainBill wanted pictures of your board. It looks like the picture in the first post and your board are NOTHING alike.
                              It is not uncommon for different board revisions to exist in the "same" monitor.
                              • rokkaholik
                                • Jul 2010
                                • 21
                                #35
                                That explains alot... I have a completely different board in mine. In fact, the power wire and video cable are soldered right to the boards. No connectors
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  Now that we are all on the same page, check
                                  1) glass fuses and picofuse to see if they are open
                                  2) test transformer using ohms
                                  3) check for cracked or poor solder joints
                                  for starters.
                                  • rokkaholik
                                    • Jul 2010
                                    • 21
                                    #37
                                    I ended up just chucking the monitor to the recycling center. I replaced the caps and still nothing. Now back to trying to fix the little Dell 17"
                                    • fairfbro
                                      • Aug 2010
                                      #38
                                      How do you know what volts they are at? There was another monitor with repair of the 680 uf cap needed and the cap read "25 V". But these are too small and have no writing on them that I can see. Maybe I need a bigger magnifying glass. Anyone know what is the voltage on this one or is it important, what range will work?
                                      Thanks!
                                      ADMIN: please change my ID from fairfbro to fairbro, or can you delete me then I can re-register? Thanks!
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        The voltage is written on the cap, but you may have to remove it from the board to actually read it.
                                        The voltage of cap has to be the same or higher than the existing one. For example, if the cap is 1uF 25V, you can substitute with a 1uF 35V.
                                        A clear focused picture ALWAYS helps.
                                        • Krankshaft
                                          • Jan 2007
                                          • 2328
                                          You'll have to PM Topcat about that one I can't edit usernames.
                                          • Danstona
                                            LG 65UK6090PUA - picture dark
                                            by Danstona
                                            Was watching this set, and suddenly it went dark. Picture is still visible, just very dark. Tried checking all settings, adjusting brightness to 100% no change. Reset through menus, no change.
                                            bought used boards from ebay (power and input boards) replaced with same results, changing brightness does seem to have a slight affect.. but not to normal visibility of picture.
                                            I'm handy, fixed TVs before.. I can't see any issues with boards... hoping someone can point me in the right direction to properly diagnose. I don't believe the LEDs are caput, since the picture is on and equal...
                                            03-10-2024, 12:41 PM
                                          • Bazfletch3
                                            Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                            by Bazfletch3
                                            Hi all
                                            While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                            I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                            From there I envisaged that the backlighting wasn't working, however...
                                            01-08-2024, 10:18 PM
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
