DCL20A screen white out
  • ninjatek
    I have a DCL20A when turned on operates normally for about ten seconds and then the screen whites out. The on indicator led remains blue indicating normal operation. If I turn off the display and turn it on again the normal image returns for ten seconds and whites out again.
    I open the casing and noticed two capacitors disfigured. I replaced them and symptoms remain the same.
    If anyone can offer some insight it will be much appreciated.
    top side of board showing disfigured caps.
    bottom of board.
    normal display during first ten seconds.
    display after ten seconds.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: DCL20A screen white out
    Were all of the secondary caps replaced?
    • EGuevarae
      • Nov 2008
      • 1336
      If all white, the Video/signal board stopped sending signal and all you can see is white because the CCFLs are still on. Or LCD Panel itself is shot.
      Krankshaft is right. You should replace all the secondary side caps
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • PlainBill
        • Feb 2009
        • 7034
        And check the caps on the logic card. There are typically three voltage regulators there. If the one that supplies the panel shuts down, it could cause this problem. Another possibility is the power supply on the panel board. That one generates the voltages required by the panel.
        PlainBill
        • harp
          White screen repairs
          by harp
          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
          05-13-2024, 03:43 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • hcinne
          Dell G15 ryzen edition black screen 2 amber 1 white
          by hcinne
          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
          07-23-2024, 07:56 AM
        • Chrissygizmo
          Panasonic TX-48CX350B backlights but white screen , blank screen
          by Chrissygizmo
          Hi all, I’ve got a problem I hope someone can help me fixi.
          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
          01-11-2025, 03:18 PM
