Question regarding testing voltages
+ More Options
Posts
  • sam67
    • 256
    Hi i have a question regarding testing for voltages on a LCD monitor..
    The pic i have just enclosed is one of my proview monitor that had bad caps which i have successfully recapped.. As you can see from the pic it has the power board and main board attached to the chassis.
    Now this monitor is working fine ,but just say for an example that this monitor was not switching on and i wanted to test at the bridge rectifier that there were the correct voltages at the 2 AC pins of rectifier and then check the main filter capacitor for the correct DC voltages.
    Now as you can see from my pic that the power board and main board are joined with a connector and that a ribbon type cable from the main board goes to the Lcd screen as do the ccfl connectors from power board.
    Now the ribbon cable is small and there is not much room to get at the main board or power board when this cable is connected to the LCD screen.
    Is it ok to remove this cable from the LCD screen side and then just leave everything else connected and test the voltages from the silk screen side of power board ( what i am saying is will removing the ribbon cable cause any issues to the voltage testing).
    Also say i wanted to do more testing on the power board but on the component side is it ok to remove both the main board and power board from the chassis and place them say on a none static surface to test more voltages ,again will this have any affect on the voltage readings when not connected to the chassis ( i.e grounding)
    Obviously it would be better if the power board was facing up with components showing for better testing in some cases.
    What do you guys do when needing to test a monitor for the correct voltages and you need more room to test and get at the right connectors to do your testing ..
    Hope i have not confused anyone with my wording lol.
    Like i say i am a newbie but wanting to get a better understanding when testing.
    I have recently been buying tools to help me along as well as some ebooks on SMPS and monitor trouble shooting but none really explain how to layout the pcbs when ready for testing .
    Hope i can get a better understanding as i am really eager to learn and this place is the best for the correct advice .
  • sam67
    • 256
    Re: Question regarding testing voltages
    I guess what i am saying is can i remove both power/main board from chassis and board from LCD screen and hook them together and power them like a sort of bench test for easier voltage testing so i have more room to test.
    • cadiman
      • Mar 2010
      • 397
      I think there are better qualified people here to answer this question than I, but you may need to post this in tv/video to get a reply. I have worked on some stuff where you really can`t get to parts of the board to check volts. I have set boards up on an insulated table (cardboard). You have to be creative when troubleshooting sometimes.
      If you have schematics you can find the test points in better places on the board your working on. If you have a working unit start logging info where you can get to it. In electronics (auto and other equipment) we call this easy pickins method. test the stuff you can reach without taking the whole thing apart. I would log all voltages from the power supply first. Good luck!
      Cadiman
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • stylishconsultant
        un60j620dafxza - Samsung No Display Problem
        by stylishconsultant
        Hi All,
        Need help.
        I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
        So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
        problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
        might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
        09-04-2024, 03:26 AM
      • DynaxSC
        Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
        by DynaxSC
        I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
        I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
        Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
        Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
        05-04-2025, 12:08 PM
