NovaTek EasyWriter
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    NovaTek EasyWriter
    I need this software to first, get the firmware image and
    then to reprogram a new NovaTek NT68F63L in a Samsung SyncMaster 913N
    I have the logic problem as described in;
    https://www.badcaps.net/forum/showth...t=samsung+913N
    Thanks in advance
  • sequille
    • 33
    Re: NovaTek EasyWriter
    i know this is ancient, but i have the same problem, the 47ohm bridging worked for like a year, now thinking of changing the chip. so, bump!
    • Nocta
      • Mar 2012
      • 117
      • Argentina
      I think it'd be better if you buy the new chip. It's not expensive.
      Novatek nt68f63lg http://www.ebay.com/itm/1-pcs-NOVATE...item415ec83896
      • sequille
        • 33
        yes, this is what i'm planning, but i can only find empty ones, i need to find a way to program it too, and i have absolutely no experience on the matter. elsewhere on this forum a person said that all i need is a LPT > VGA cable and after some reading it seems it means the chip supports In-Sytem Programming but i need a confirmation. Also, that cable is not easy to find so i was thinking since most of the pins are reserved maybe i just need to connect two or three wires, like pin 12 on the vga and some ground, but to what pins on the parallel port?
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          Hi, did you managet to get firmware and software.
          I need to flash IC, please help
          ...the quieter you become the more you are able to hear...
          • soopacrucial
            Samsung Syncmaster 740BF repair
            by soopacrucial
            Hi folks,
            I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
            Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
            10-29-2024, 02:40 PM
          • nh2
            Samsung SyncMaster 215TW buzzing / lightning in power board socket
            by nh2
            This is my first post here. I just fixed my first 2 broken displays by replacing broken capacitors (Samsung SyncMaster 226BW, and Samsung SyncMaster 213T). But I have a third one I'm unable to fix, and am eager to fix as well:
            My Samsung SyncMaster 215TW makes a buzzing / hissing sound when turned on.
            The sound is louder the brighter the monitor is, e.g. in the "Game" preset is is even louder than in a softer preset.
            Opening up the monitor and unplugging the small socket cables that run from the power board to the LCD, I can see a small blue...
            08-31-2021, 02:23 AM
          • madfreak
            ASUS FA506IV does the KBC will reprogram by itself ?
            by madfreak
            Hello You all, I hope You are all safe and healthy
            I got a question about KBC in that laptop
            ( ASUS FA506IV / motherboard DABKXBMBAD0 rev. d )
            ...that laptop is not charging and not powering on battery but when i plug the dc charger the LED indicator on laptop is turning orange like it was charning ...but it's not.
            I have changed the ic charger BQ24780S and the mosfets near by but the problem still is there so i think that maybe because a short curcuit there is something wrong with the KBC ( laptop is working perfectly fine and stable only...
            05-27-2022, 08:02 AM
          • rattlesnake
            Samsung SyncMaster 955DF dim image fix
            by rattlesnake
            This display looks a bit dim but the image is otherwise fine. I already set the contrast to 100 and the brightness to 50 (more than that is counterproductive, it becomes hazy).
            To enable extra tuning, I have to enable the "Highlight Zone" function and stretch it to full screen. That way it looks really bright/intense and really good! I wish I could set it permanently like this, but as soon as you change the display mode/resolution or you turn the monitor off, you lose the "Highlight zone" config and you have to manuallly activate it again. Also, the manual says...
            08-12-2023, 07:03 PM
          • vincentedel
            Samsung SyncMaster 740n Phase Control Issue
            by vincentedel
            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
            04-22-2025, 12:33 AM
