Dell U2410F smudging
  • mikolajj
    • Nov 2017
    • 9
    • Polska
    I got old monitor and it's smudging a lot.
    Old image is left on black, window frames leave sharp llines...
    Is this fixible issue?
  • Offscreen6
    • Jan 2021
    • 22
    Re: Dell U2410F smudging
    This is pretty hard to diagnose since there could be multiple things going on here.
    The best information I could find on this problem is ghosting (which is basically a bad refresh rate) and image retention (which is fixed just by having the monitor off for a long time, and it looks a lot messier than this from what I can see).
    Now I DID see like 3 similar complaints for this model on the Dell support site, but only 2 of them were solved and they were solved with buying a new monitor.
    The closest resemblance I know to this problem is that of a projector with a bad lamp, but I don't think that should have any bearing on an LCD monitor.
    How long are you keeping this monitor on? How long does the smudge last?
    • mikolajj
      • Nov 2017
      • 9
      • Polska
      It was turned on for few years, lets say 8-10 hours a day. Then It was off for about a year.
      The smudges last for few minutes - depending on background, contrast intensity etc.
      As I'm thinking about this problem I can imagine that there is an issue with something that should give sharp edge of information on = 1, off=0 but sometimes it stays in almost 1 or almost 0 state, then the matrix does turn the pixel on and off - sth. like button bouncing.
      Any idea what should I check first ?
      • Borse2008
        Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
        by Borse2008
        Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
        I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
        • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
        • There’s
        07-15-2025, 04:55 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • DanPoka
        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
        by DanPoka
        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
        02-15-2025, 05:05 AM
        by momaka
        03-15-2023, 10:17 PM
      • Jesus Coder
        Issues Reviving Old Dell 2408WFPb Monitor
        by Jesus Coder
        I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
        06-25-2023, 02:33 PM
