Dell LCD E198WFPF no power
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell LCD E198WFPF no power
    Originally posted by albertwong
    reinitializing the EEPROM?
    Sounds like some special programming device is needed.
    As I noted earlier, I have the identical problem with a Dell E177FPf. The power LED does not come on, and there is no CCFL activity. Here are the results so far:
    Main power supply output - good
    Physical appearance and ESR of all caps - good
    Outputs of on-board regulators - good
    Crystal for processor - oscillating
    Signals from front panel buttons - good.
    This monitor has only three ICs in the 'logic card' section, a gm2621-LF, a 24C02WI, and a Pm25LV010. It appears the Pm25LV010 holds the firmware, and of course the 24C02WI holds user settings. I've got a replacement on order for the 24C02 and will see if by some slim chance that fixes the problem.
    PlainBill
    • albertwong
      • Jan 2010
      • 31
      #42
      Originally posted by eguevarae
      Would be very (VEEEEERYYYYYY) difficult
      That sounds like impossible to get it.
      I am learning.
      • albertwong
        • Jan 2010
        • 31
        #43
        PlainBill
        I purchased another logic board. However, when I put in, the screen has vertial white lines instead of normal display. So is it not the problem of the logic board? I will take a picture of it tonight.
        I am learning.
        • albertwong
          • Jan 2010
          • 31
          #44
          I plug in the new logic board and found out that the display is a blank white screen.
          I tried connecting to my computer and still the same.
          It is like the flex cable was not connected.
          The power indicator light is green though.
          I am learning.
          • PlainBill
            • Feb 2009
            • 7034
            A white screen is usually caused by an open fuse on the panel or a cable that is not properly seated. Also, check the pins at the lower end of CN106 (the connector to the panel). I'm sure power to the panel is on some of those pins.
            PlainBill
            • albertwong
              • Jan 2010
              • 31
              #46
              What is the power suppose to be on CN106?
              5V?
              If it is an open fuse on the panel, is it fixable?
              I am learning.
              • PlainBill
                • Feb 2009
                • 7034
                5V?
                It depends on the panel; probably 5 volts.
                The fuse can be replaced; however it may have blown because something else was shorted.
                PlainBill
                • albertwong
                  • Jan 2010
                  • 31
                  #48
                  from pin1 of the connector to panel:
                  4.92
                  4.92
                  4.92
                  0
                  0.01
                  0.02
                  0.01
                  1.14
                  1.34
                  1.24
                  1.21
                  1.18
                  1.31
                  0.01
                  1.16
                  1.33
                  0.02
                  1.14
                  1.34
                  1.14
                  1.33
                  1.24
                  1.22
                  0.02
                  1.17
                  1.32
                  1.14
                  1.33
                  0.42
                  0.01
                  Is it normal?
                  It got the 5V though.
                  Where should I check for the open fuse on the panel?
                  I am learning.
                  • albertwong
                    • Jan 2010
                    • 31
                    #49
                    I opened up the panel and checked F1. It is good.
                    What else can i checked?
                    I am learning.
                    • aubrey52
                      • Nov 2009
                      • 29
                      #50
                      if you have no power ck diode d851 on power/invert board. remove from board
                      FR107m is same fr107
                      Description: 1000 V, 1 A, fast recovery diode
                      Manufacturer:
                      Package: DO-41
                      Pins: 2
                      checked the power/inverter board.
                      resolder all round invert Transformer you have some bad solder on connt
                      thanks
                      and i hop this help i just fix monitor by doing this
                      Aubrey52
                      • albertwong
                        • Jan 2010
                        • 31
                        #51
                        Manufacturer:
                        Package: DO-41
                        Pins: 2
                        thanks
                        Aubrey52
                        Thx. I will try that. So what problem your monitor was experiencing? Do you have the same monitor?
                        I am learning.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          This is a waste of time and effort for your problem. Aubrey52 described a fix for a dead power supply. Your power supply is working.
                          PlainBill
                          • aubrey52
                            • Nov 2009
                            • 29
                            #53
                            PlainBill did he not say this on page 1 Dell LCD E198WFPF with no power, not even the green power light on the monitor.
                            albertwong said
                            he also said that I purchased another logic board. However, when I put in, the screen has vertial white lines instead of normal display. So is it not the problem of the logic board? I will take a picture of it tonight.
                            albertwong said
                            i do know that PlainBill is very good man
                            help me befor parts
                            what i am saying put your old logic board back in montor. ck what i said
                            your makeing more problem. by use differ logic board.
                            i don/t thanks it your logic board.
                            what bill said is right is for powersuppy and inverted board. and thank you haveing same thining happening.
                            went fine fix let me know
                            have a good
                            Aubrey52
                            just ck it d851 if read 2 ohm both way it bad
                            good luck
                            • PlainBill
                              • Feb 2009
                              • 7034
                              help me befor parts
                              have a good
                              Aubrey52
                              good luck
                              Look at this post. Albertwong found a 5 volt output from the power supply. That same voltage is found on the logic card, as well as other voltages used by the processor. That shows the power supply is working.
                              One of the biggest mistakes amateurs make is believing all instances of a problem must have the same cause. You saw 'no power' and acted like every case of 'no power' must be caused by a shorted diode. If you think about it, you will realise how foolish that idea was. Let's make a short list of possible causes for that problem:
                              1. Electrical outlet dead.
                              2. Power cord not plugged into the outlet.
                              3. Power cord not plugged into the monitor fully.
                              4. Blown input fuse in monitor
                              5. Blown NTC
                              6. Startup capacitor for the SMPS controller bad
                              7. Bad solder joint on the power connector on the monitor.
                              8. Bad main filter cap.
                              9. Blown output fuse in power supply.
                              10 Bad output caps in power supply.
                              11. And there are even more reasons involving shorted diodes, transistors, open fuses, etc.
                              I'm sure you mean well, but you don't understand how the power led on a monitor works. Think about how a monitor works.
                              You plug in the power cord, but not the video cable. The power light goes green, (or blue). A message appears on the screen - "No signal". A few seconds later the screen goes black and the power LED turns orange.
                              You push the power button. Now the power LED turns off.
                              You push the power button again. The power LED goes green or blue, the 'no signal' message appears again, and again after a few seconds the screen black and the power LEE goes orange.
                              You hook it up to a computer and turn the computer on. Now the power LED turns green (or blue) and you see the POST messages as the computer boots.
                              If you looked at the schematic for any monitor you would see that the power led is controlled my the video processor. So a 'Not even a power LED' problem can mean a bad power supply, or it can mean a problem on the logic card.
                              PlainBill
                              • aubrey52
                                • Nov 2009
                                • 29
                                #55
                                Hi
                                PlainBill
                                thanks you
                                very much for help; i sure it will help me download road.
                                i do know one thing that power suppy is not only items that can be bad.
                                i was trying help him best i could. this why don,t ask for help on line to much
                                your are a good man bill. i sure do thanks you
                                for all your help.
                                Aubrey52
                                have a very good day went fine out what bad in montor you are working on
                                17" dell let me know. i sure don;t have all parts you do.
                                i thank you are very good man. yes lcd are litte new to me.i was a repair man
                                on vcr and tv set day gone for that.do know how startup work lcd for have book on this. and how repair lcd montor.
                                • albertwong
                                  • Jan 2010
                                  • 31
                                  #56
                                  aubrey52. Thank you for your help. Unfortunately, the information is not helping in this case. However, I am sure if you keep up the good work, you will be able to help other people.
                                  I am learning.
                                  • aubrey52
                                    • Nov 2009
                                    • 29
                                    #57
                                    Hi
                                    albertwong.
                                    your very welcome. i do know more what some thanks i do.
                                    i build my owen computer i work on laptop and disk top.
                                    i fix lot montor .and not one have come back.
                                    so best for me just let rest do all helping on here.
                                    just let me know what you find out went you fixing your montor. really hop some one on here can help you get it working
                                    have a good day
                                    Aubrey52
                                    try to send you a email won;t work
                                    good luck
                                    • albertwong
                                      • Jan 2010
                                      • 31
                                      #58
                                      I found a service manual for E178wfpc.
                                      It could be similar.
                                      Does anyone have any idea?
                                      I am learning.
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
                                      • Powderfanupnorf
                                        Dell AL440LX power on switch circuit help required
                                        by Powderfanupnorf
                                        Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                                        So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                                        My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                                        06-24-2024, 01:24 PM
                                      • PantherDave
                                        by PantherDave
                                        Hi all!
                                        I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
                                        05-29-2024, 02:01 PM
                                      • MyBrainIsAStrainer
                                        Asrock H87-Pro4 Rev. G/A 1.04: Power cycling on reset only
                                        by MyBrainIsAStrainer
                                        Hi!
                                        I have a weird one for you. I have a H87-Pro4 from Asrock that power cycles. But only when you do a restart after it was already running!
                                        Symptoms in detail:
                                        1. I switch off the ATX PSU for ~15-20 seconds, then switch it back on again.
                                        2. I press power button. The board boots without issues.
                                        3. I can shut down the board any way I want (via OS* menu, or pushing the power button - either in the OS or the boot manager).
                                        4. Push power button again, board boots fine.
                                        5. This shutdown/powerup can be repeated multiple times without problems.
                                        6. BUT: If I do a restart instead
                                        06-25-2023, 02:44 PM
                                      • Mark01
                                        Dell Optiplex 7490 AIO - red power led after flash
                                        by Mark01
                                        Hi guys,
                                        This is my first post! πŸš€
                                        I have no idea what I’m doing, but I’m learning by trial and error.
                                        I’m currently working on a Dell Optiplex AIO 7490β€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                        07-04-2025, 12:54 PM
