Dell LCD E198WFPF no power
+ More Options
Posts
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell LCD E198WFPF no power
    Originally posted by albertwong
    I see. Thanks for the explaination. I found my oscilliscope yesterday. However, I cannot find the probe. I think I placed those in some other location. I will try to find those probes today and see what the processor got.
    I've had days like that. I STILL haven't found my isolation transformer.
    PlainBill
    • albertwong
      • Jan 2010
      • 31
      I found my probes and checked the board.
      I connected the probe to both pins of the crystal instead of the processor. The pins on the processor is just so small that I am scared that I will short some pins when I measure.
      I seems like there are signals.
      Please see the attached pictures.
      By the way, I was using channel 2 of the scope.
      I am learning.
      • PlainBill
        • Feb 2009
        • 7034
        The amplitude is good, but it looks to me like you have a frequency of about 70 Khz. The doesn't make sense. I would have expected 14 Mhz.
        PlainBill
        • pedro
          • 199
          • AUSTRALIA
          PlainBill
          It's unclear whether the x10 is selected on amplitude or TB, Bill. But 2.5div of amplitude at 50mV/div is a bit short.
          Certainly that isn't the waveform I'd expect on either xtal pin. Something wrong - wrong pin maybe, or the oscillator circuit trying to excte the xtal? I'd like the OP to zoom in on those included angles after the H-L transitions, as it may be the oscillator trying to start at xtal freq.
          Friends don't let friends buy Samsung ....
          • PlainBill
            • Feb 2009
            • 7034
            You could be right; I was assuming a 10X probe.
            PlainBill
            • albertwong
              • Jan 2010
              • 31
              #26
              Yes, it is 10x probe.
              I connected my probe to both pins behind the crystal on the board. Is that how I should connect? I did not connect to the processor.
              So how should I change the setting on my scope?
              I had a hard time making my scope work. I will take a full picture of the face panel of my scope tonight so that you can have a better idea of what setting I have.
              Let's say if the frequency of the crystal is not right, then could it be the crystal not working?
              Should I replace the crystal?
              Hi Bill, I just saw that you will be having a cataract surgery on May 19, 2010. I wish everything will be going smooth and you will recover soon.
              I am learning.
              • PlainBill
                • Feb 2009
                • 7034
                Connect the scope ground to circuit board ground. Connect the scope probe to either side of the cap. One side should give a stronger signal; use that side.
                PlainBill
                • Radio Fox
                  • Jan 2010
                  • 281
                  The timebase is uncallibrated in your photo. Turn the orange variable knob on the TIME/DIV fully clockwise to the CAL'D position.
                  Measure the Xtal as PlainBill says. Try to do it without the extra red croc clip lead. This will give a clearer image.
                  ________________________________________________
                  Invisible airwaves crackle with life
                  Bright antennae bristle with the energy
                  • albertwong
                    • Jan 2010
                    • 31
                    #29
                    Here is a full picture of what control I have in my scope.
                    I am learning.
                    • albertwong
                      • Jan 2010
                      • 31
                      #30
                      I measured it again with the new suggestion.
                      I turned the TIME/DIV fully clockwise to the CAL'D position.
                      connect ground of the scope to the board ground and connect the probe to either side of the crystal. The ground of the probe is not connected.
                      I got some signals. But not matter how I turn the delay, the wave won't stop moving. I cannot stabilize the display.
                      I took a picture of it.
                      10x probe
                      .1V/Div
                      I am learning.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        10x probe
                        .1V/Div
                        Some suggestions:
                        1. Upper right corner. Set Sweep Mode to Norm; Source to Ch2.
                        2. Upper center, set Hor Display to A
                        3. 'A Time / Div and Delay Time'. Make sure red knob is pushed in and rotated fully clockwise.
                        4. Adjust Holdoff knobs to stabilize the display. Adjust gray knob under 'A Time / Div and Delay Time' to show several cycles of the waveform.
                        PlainBill
                        • albertwong
                          • Jan 2010
                          • 31
                          #32
                          Some suggestions:
                          PlainBill
                          Thx for the suggestion.
                          A few questions.
                          Can you explain a little bit more about what the sweep mode, source and hor Display is?
                          I am always curious about what are those.
                          Also, on the holdoff knobs, there is a grey small knob on top of the big one. What's the different?
                          WHen I first got the scope, I was having a hard time stablilzing the screen. So I am thinking it is not working properly. May be I just have the wrong setting.
                          Thx for teaching me so much.
                          I am learning.
                          • albertwong
                            • Jan 2010
                            • 31
                            #33
                            I have just checked the crystal with the new settings.
                            Here is what I got.
                            I think there is some signal from the crystal.
                            I am learning.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Here is what I got.
                              I agree.
                              PlainBill
                              • albertwong
                                • Jan 2010
                                • 31
                                #35
                                So is there anything else I can check?
                                I am learning.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Nothing that I can think of. Perhaps in the near future, however.
                                  I've got an identical problem with another Dell monitor, a E177FPf. The interesting thing is it's a totally different system. Power supply, inverter and logic all on one board. The processor chip is also different. I'm going to be going over it carefully to see if I can figure out what is going on. The only thing I can think of trying is reinitializing the EEPROM.
                                  PlainBill
                                  • albertwong
                                    • Jan 2010
                                    • 31
                                    #37
                                    reinitializing the EEPROM?
                                    Sounds like some special programming device is needed.
                                    I am learning.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Not necessarily. On many monitors you can do a reset by holding down certain buttons, then plugging it in. I'm not at all sure that that will work in this case, usually a monitor with a corrupted eeprom will at least flash the power button.
                                      PlainBill
                                      • albertwong
                                        • Jan 2010
                                        • 31
                                        #39
                                        Do you know if I can obtain the service manual for this monitor anywhere?
                                        I am learning.
                                        • EGuevarae
                                          • Nov 2008
                                          • 1336
                                          Would be very (VEEEEERYYYYYY) difficult
                                          There are 10 kind of people in this world: those that understand binary, and those who don't.
                                          • ASUS ROG Maximus IX Code
                                          • Intel Core i5-7600K 3.8GHz
                                          • 16gb GSKILL TridentZ RGB DDR4-3200
                                          • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                                          • Windows 10 Pro x64
                                          • GeForce GT1050
                                            2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Powderfanupnorf
                                            Dell AL440LX power on switch circuit help required
                                            by Powderfanupnorf
                                            Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                                            So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                                            My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                                            06-24-2024, 01:24 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
                                            05-29-2024, 02:01 PM
                                          • MyBrainIsAStrainer
                                            Asrock H87-Pro4 Rev. G/A 1.04: Power cycling on reset only
                                            by MyBrainIsAStrainer
                                            Hi!
                                            I have a weird one for you. I have a H87-Pro4 from Asrock that power cycles. But only when you do a restart after it was already running!
                                            Symptoms in detail:
                                            1. I switch off the ATX PSU for ~15-20 seconds, then switch it back on again.
                                            2. I press power button. The board boots without issues.
                                            3. I can shut down the board any way I want (via OS* menu, or pushing the power button - either in the OS or the boot manager).
                                            4. Push power button again, board boots fine.
                                            5. This shutdown/powerup can be repeated multiple times without problems.
                                            6. BUT: If I do a restart instead
                                            06-25-2023, 02:44 PM
                                          • Mark01
                                            Dell Optiplex 7490 AIO - red power led after flash
                                            by Mark01
                                            Hi guys,
                                            This is my first post! πŸš€
                                            I have no idea what I’m doing, but I’m learning by trial and error.
                                            I’m currently working on a Dell Optiplex AIO 7490β€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                            07-04-2025, 12:54 PM
