Questions about building CCFL Tester
  • Radio Fox
    • Jan 2010
    • 281
    Re: Questions about building CCFL Tester
    Originally posted by Welchs101
    Put new batteries in ............. same result. Only 125V AC on output and no lamp coming on. Oh well, i think the inverter is fried or something.
    Have you tried measuring the output on "out 2" as well?
    What is the maximum range on your multimeter?
    Just a thought, but have you set it to measure AC, rather than DC?
    ________________________________________________
    Invisible airwaves crackle with life
    Bright antennae bristle with the energy
    • Welchs101
      • Sep 2008
      • 979
      I dont know what the max value i can measure is ...........but i know its more than 125V as i just measured 240V AC on my water heater.
      Yes, i measured 125V AC. That was the first thing i checked. But to be sure i can check again.
      • Welchs101
        • Sep 2008
        • 979
        Let me just say KRANKSHAFT was right. That little "inverter" is VERY VERY VERY VERY VERY DANGEROUS! I almost started a FIRE! No joke! I took all safety precautions and still almost started a fire. So i abandoned the little inverter idea and went with another approach.
        I took an existing (working) LCD monitor. I soldered onto the inverter board two wires. The wires were soldered onto the "connector" where the CCFL lamp plugs in. I used these two wires to test the lamps. Sure enough the lamp which was "bad".........came on for a sec then went off. Where as a good lamp stayed on.
        The "bad" lamp when tested with the little inverter almost started a FIRE. I plan on re-reading KRANKSHAFTS comments and only using an inverter setup like he suggested.
        I have learned on alot on this little exercise. thanks to all the people who provided support! Thanks.
        • PlainBill
          • Feb 2009
          • 7034
          Well, as long as you're happy, that's good. I would have enjoyed pictures of a fire, though. It's only supposed to get up to 63Β°F today!!!
          PlainBill
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
          • repair-it
            TOSHIBA DLP 52HM95 How to reset timer module on bulb
            by repair-it
            I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
            Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
            10-11-2023, 07:18 PM
          • ezenia
            LUMIMAN Smart Bulb IC ID?
            by ezenia
            I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
            In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
            04-28-2025, 05:56 PM
          • BOSCHNJAK
            by BOSCHNJAK
            ABOUT ME INTRODUCTION FILE
            2
            024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
            2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
            2022 BEV, PROJECT ?
            2021 BEV, PROJECT ?
            2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
            2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
            12-28-2023, 02:09 PM
          • Gentian
            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
            by Gentian
            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
            03-06-2023, 07:07 AM
