dell E173Fpf
  • serg752
    • Jan 2010
    • 17
    dell E173Fpf
    I have the model of liquid crystal display Dell E173Fpf with the following problem:
    The monitor is not connected with the computer, when I feed the monitor on 120 volts, the screen ignites automatically and the green temoin lights(switches on), there is no image and I am not capable of closing the monitor with the power button, it always remains lit(switched on) I verified 2 condensers 220uf 16V and is o.k.
    What components should I verify?
    Serge
  • PlainBill
    • Feb 2009
    • 7034
    Re: dell E173Fpf
    Serge
    Verify the output voltages of the power supply if you haven't done so. Then verify the processor on the logic board is working.
    PlainBill
    • EGuevarae
      • Nov 2008
      • 1336
      Re: dell E173Fpf
      Serge
      How did you verify them?
      What about other caps in the PSU?
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • Borse2008
        by Borse2008
        • There’s
        07-15-2025, 04:55 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
        by momaka
        03-15-2023, 10:17 PM
      • Jesus Coder
        Issues Reviving Old Dell 2408WFPb Monitor
        by Jesus Coder
        I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
        06-25-2023, 02:33 PM
