LG 34UM59 white “washed out” image
  • occhia
    • Jun 2017
    • 27
    • Italia
    Re: LG 34UM59 white “washed out” image
    Ok understood.. thanks a lot for the reply.
    Do you mean the “SW0686” chip, correct?
    Can I do something like this?
    https://youtu.be/eA1qsnRuS_Q
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4305
      • Italy - Milan
      Sorry i've noticed now there's another chip, it's U51 i think
      • occhia
        • Jun 2017
        • 27
        • Italia
        Ok thank you, compatriot!
        So, you suggest to try reflowing the RT6811 chip with Heathgun and see what happens?
        And.. so, this is the DC-DC and gamma ic chip? I'm just asking to learn..
        Thanks!
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4305
          • Italy - Milan
          I'm not really sure what it is but i think is a pmic+gamma chip, but just to be sure, on the leftmost i see those gamma testpoint named like V12,V8.. etc, check with dmm to which chip are connected.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4305
            • Italy - Milan
            take the multimeter sat in continuity (beep), then place one probe on the test point the other on one of the two chips, if it beebs theme are connected.
            • occhia
              • Jun 2017
              • 27
              • Italia
              #26
              Ok this evening I will check and post updates.
              Thanks a lot, really.
              • occhia
                • Jun 2017
                • 27
                • Italia
                #27
                Hello everyone!
                I did some testing.
                For the continuity test between those points (from V1 to V14) some of them show continuity with some pins of the RT6811 chip (marked as U51 on the board). These point are V3/4/5 and 10/11/12. The other points do not beep with no one of the pins of that chip.
                I also tried the voltages on those points and they all have tensions, decreasing gradually from about 11v to 1v (V1=11v, V2= 10.5v, V3=9.7v and so on..)
                Thanks for help.
                • occhia
                  • Jun 2017
                  • 27
                  • Italia
                  #28
                  No one has some suggestions?
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • x_orange90_x
                    TCL 50S535 bad tcon or panel issue?
                    by x_orange90_x
                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                    03-29-2025, 11:02 PM
                  • jason123
                    Hisense 65R6E3 double-image / horizontal strips - TCON?
                    by jason123
                    Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                    07-19-2025, 08:07 AM
                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:20 PM
                    MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                    This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-06-2024, 07:46 AM
