HP VS17X Monitor issues
+ More Options
Posts
  • oreo1
    • Oct 2009
    • 27
    I was given an HP VS17X monitor that will not come on at all. The power light comes on, but the monitor will not and I could not see if the backlight was coming on briefly or not. I ulled it apart and found two bad caps that had bulging tops, one with an orange substance on the top.
    After reading a lot I found that ALL of the capacitors on this board are on your bad caps list. I have included a list of all caps with specs and some photos. Could someone kindly point me in the right direction as to where the best place would be to find suitable replacements? Thank you in advance for any assistance!!
    x1 - Su'Scon 100uf 450v UK 105 degrees
    x1 - Su'Scon 470uf 16v UK 105 degrees
    x3 - Su'Scon 470uf 25v MC 105 degrees
    x1 - Su'Scon 100uf 16v UK 105 degrees
    x3 - Su'Scon 100uf 25v SK 105 degrees
    x3 - Su'Scon 10uf 16v SK 105 degrees
    x2 - Su'Scon 4.7uf 16v SK 105 degrees
    x1 - Su'Scon 10uf 16v UK 105 degrees
    x1 - Su'Scon 82uf 35v UK 105 degrees
    x2 - Su'Scon 2.2uf 50v UK 105 degrees
    x1 - Su'Scon 1uf 50v UK 105 degrees
    x2 - Su'Scon 1000uf 25v UK 105 degrees
    x2 - Su'Scon 470uf 35v MC 105 degrees
    x2 - Su'Scon 220uf 35v MF 105 degrees
    x3 - Su'Scon 2.2uf 50v SK 105 degrees
    X3 - CapXon 1000uf 10v KF 105 degree
    Thanks again for any help with getting this thing going again!!
  • PlainBill
    • Feb 2009
    • 7034
    Re: HP VS17X Monitor issues
    This appears to be a design which combines power supply, inverter, and controller onto a single card. Interesting.
    Ordinarily I would jump in and list suggested replacement parts, but you didn't include dimensions of the existing caps. Refer to the 'Frequently Asked Questions' subforum, and review the list under 'which caps should I buy'.
    This is an updated procedure for selecting caps.
    Go to www.digikey.com. Near the top right corner of the page is a box with Part Number / Keyword. Enter capacitor and click Go.
    Click on Aluminum.
    Under Series select the series of caps you believe are acceptable. I usually limit myself to Panasonic FC and FM, but don't hesitate to select more.
    Under Capacitance select the value you need.
    Under Voltage select the voltage
    Under Package/Case select Radial
    Place a check mark by In Stock, then click Apply Filters
    Now I just did this for 680 uF 10 V and got exactly 4 hits. Looking over the specs, I see Panasonic FC and FM in two case sizes. I also note that FM series is rated for a longer life, and costs less. So I click on the Stock Number for the proper case size. On this page I enter the Quantity and click on Add to Order.
    Alternatively I can copy the Digi-Key Part Number and Manufacturer Part Number to a list and someone else can use these to place an order.
    Then I repeat the process.
    I prefer Digi-Key because they have good prices, a good inventory, and offer a First Class Mail shipping option. This will get your order to you in two days for about $2.00 in shipping.
    Note that in some cases dimensions are critical. Make sure the parts you select are not too tall or to wide to fit!!
    PlainBill
    • fadec
      • Jan 2010
      • 10
      PlainBill, You could have just copied and pasted that reply directly into my dumb post. As we are asking basically the same thing. Though I'm looking for Rubycon and Digi-Key does not carry them, brand is not set in stone... I'm flexible enough to try other good quality caps.
      After using Digi-Key's search filter I'm comfortable enough with the good info they give as to select something that should fit my needs.
      Thanks for the info and link.
      • endevite
        • 48
        Working on a list, give me a bit. (In case you wanted help on a cap suggestion list.)
        • endevite
          • 48
          Cap Suggestion (Digikey should carry all of these)
          Standard Series UK (All have unknown Impedance & 3k hr lifespan)
          18x40 572ripple
          use Chemi-con KXG 450v 100uf 18x40 800ripple@120hz 1800ripple@100k,10k hr lifespan
          8x14 427ripple
          Use 8x15 Chemi-con KY series (840 ripple @ 7k hr lifespan)
          6.3x11 141ripple
          Use 6.3x11.5 Chemi-con 25v 100uf KY seres 340Ripple @5k hr lifespan
          5x11 39ripple
          Use Chemi-con KY 50v 10uf 5x11 100ripple rating 5k hr lifespan
          10x20 919ripple
          Use Nichicon VR 10x20 25v 1000uf @ 960 ripple
          Not even listed (UK series lists no existance of 82uf except in the 100v to 450v chart)
          I would use Chemi-con LXV 35v 82uf 6.3x11 330ripple @2k hr lifespan
          I can come up with better options if I knew the dimensions of the cap.
          5x11 22ripple
          Use 5x11 Chemi-con 50v KY 2.2uf (43ripple @5k hr lifespan)
          5x11 14ripple
          Use 5x11 Chemi-con 50v 1uf KY (30ripple @5k hr lifespan)
          Standard Series SK (All have unknown Impedance & 2k hr lifespan)
          6.3x11 163ripple
          User Chemi-con KY 6.3x11 25v 100uf 340Ripple 5k hr lifespan
          5x11 42ripple
          Not even listed (However 25v 4.7 is @ 5x11 30ripple)
          Use Chemi-con KY 5x11 50v 4.7uf 88ripple 5k hr lifespan
          5x11 15ripple
          Use Chemi-con KY 5x11 50v 2.2uf 43ripple 5k hr lifespan
          Low Impedance MC
          10x20 1050ripple 64miliohm 3k hr lifespan
          Use Chemi-con KY 10x16 25v 470uf 60miliohm 1210ripple 7k hr lifespan
          13x21 1370ripple 39miliohm 3k hr lifespan
          Use Chemi-con KZE 35v 470uf 10x20 23miliohm 1820ripple 4k hr lifespan
          Low Impedance MF
          10x16 820ripple 85miliohm 5k hr lifespan
          Use Chemi-con KY 35v 220uf 10x12.5 80miliohm 865ripple 7k hr lifespan
          Low Impedance KF
          10x16 1040ripple 76miliohm 5k hr lifespan
          Use Chemi-con KY 10v 1000uf 10x16 60miliohm 1210ripple 7k hr lifespan
          • oreo1
            • Oct 2009
            • 27
            I can't thank everyone enough for their help in getting this going, especially to PlainBill, & endevite for taking the time to put together that awesome replacement list!! Endevite, in answer to your one question about the dimensions of the x1 - Su'Scon 82uf 35v UK 105 degrees, the dimensions are 8x11. I hope that helps or confirms your replacement recommendation.
            Many thanks again for all of the help with this project!!
            • endevite
              • 48
              Is there height clearance for 8x15? Chemi-con 8x15 KY 63v 82uf 665riiple 7k hr lifespan would be the better cap.
              • oreo1
                • Oct 2009
                • 27
                Endevite,
                Sorry for the delay in getting back....sometimes life's situations trump our hobbies. Anyway, no, unfortunately they will be a little to large for the spot. Thanks though, and thanks again for all of the other help. The caps are all in....great quick shipping from Digi-Key and now I'm going to work!!
                • oreo1
                  • Oct 2009
                  • 27
                  A quick update and again many thanks to PlainBill & endevite for all of your help!! All caps replaced and another monitor saved from the scrap heap. It works great and is a pretty sharp LCD monitor. Thanks again!!
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    I received one these and changed out 3 bulging Capxon 1000uF 10V KF (P630) caps. The monitor was made in Aug 2006.
                    I noticed that the HP has a stored memory function. Some interesting facts.
                    Monitor has been on for 29,984 hours (or 3.4 years). So it looks like the previous owner never turned it off or just let it go to sleep mode.
                    Backlight hours is 9,354 hours. So he got about 13 or 14 months use before the Capxon caps died.
                    Now to be fair, the Capxon caps are situated right next to the output transistor which was mounted on a large heat sink. And in this design, the hot air from that transistor flows UP right into the Capxon as you can see in the OP's picture.
                    --- begin sig file ---
                    --- end sig file ---
                      by momaka
                      03-15-2023, 10:17 PM
                    • keepread
                      Dell monitor PSU vs Dell laptop PSU
                      by keepread
                      Hi there!
                      Someone gave me their old monitor, it's Dell S2715ht.
                      The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                      Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                      10-30-2025, 04:45 PM
                    • Jesus Coder
                      Issues Reviving Old Dell 2408WFPb Monitor
                      by Jesus Coder
                      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                      06-25-2023, 02:33 PM
                    • wattage
                      by wattage
                      Hello Badcaps Community,
                      07-13-2025, 04:41 PM
                    • Rick_1234
                      by Rick_1234
                      Good evening, gentlemen.
                      Things I tried
                      06-22-2024, 04:44 PM
