Have just inherited one of these monitors which shows no sign of life at all, not even a green led on the on/off switch which it should display. On opening it I found a surface mount Elna cap 470uf 16v wide open at the top with electrolyte sprayed out onto the coverplate of the circuit board. Not having any of this type I replaced this and the only other similar cap with two through hole caps of equivalent specs but can still get no life at all from the monitor. I can get a reading of 12v on one lead going from the logic board to the seperate inverter board ( there is no power board as such as the power is supplied from a 12v external power supply) but no other reading at that connector (ie no 5volt). The only other thing I have found is that the fuse on the inverter board appears to have failed but the caps on the board are fine and even temp wiring across the fuse produces no life.
As I have not seen one of these monitors before and there is little on the forum or net on faults with them just thought i would ask if anyone has had similar faults on one to point me in the right direction. Unfortunatelly cant get a photo of the thing at the moment to post but will try.
Also can anyone point me to a simplistic explanation of the direction of power flows from the on/off switch/LED throught the inverter and back as it were as I still dont fully understand the backlight control mechanism?
Many thanks for any help offered - it is very much appreciated.
Regards
Johnboy183
Regards
Johnboy183
