Do you think the the monitor in this post has bad caps?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    A person at ocforums.com has a problem with a monitor giving a messed up picture. At first, it would go away sometime after being on and 2 years later, it's completely blurry.
    http://www.ocforums.com/showpost.php...0&postcount=15
    http://www.ocforums.com/showthread.p...05#post3879305
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • bushytails
    Moderator
    • Dec 2004
    • 217
    Re: Do you think the the monitor in this post has bad caps?
    blurry sounds more like a focus/screen network problem...
    --Randy
    • black6host
      Replacement caps for Samson Resolv studio monitor 65A Amp board.
      by black6host
      Good day!
      I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
      I'm going to replace the caps and I'll be the first...
      02-06-2024, 08:22 PM
      by momaka
      03-15-2023, 10:17 PM
      by momaka
      03-12-2025, 03:42 PM
      Westinghouse L2210NW LCD monitor - bad caps repair
      by momaka
      Here's another LCD monitor repair: Westinghouse L2210NW.
      Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
      I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
      Pictures of the monitor outside/case after a brief...
      01-11-2021, 01:14 AM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
