screen resolution vs monitor size
+ More Options
Posts
  • doudou
    • Nov 2009
    I have recently downgraded from a 18inch to a 17inch screen, and have noticed that the webpages are too big for my 17inch - that I have to scroll across pages to read. It never happened to me when I was on my 18inch, with resolution set on 800x600.
    The only option I have is to adjust my resolution, changing from 800x600 to1024x768..but I'm so used to working on 800x600 resolution and dont really feel comfortable with smaller desktop icons and font size.
    As I want to stay on 800x600 without having to scroll, I was wondering if exchanging for a 19inch would help?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: screen resolution vs monitor size
    no, pages are measured by pixels not inches.
    BUT
    a 19" on 1024x768 would be similar to 800x600 on a 17".
    so the upgrade would help if you changed resolution.
    sigpic
    (Insert witty quote here)
    • doudou
      • Nov 2009
      euh......so no first but yes ?
      Not quite sure if i got this right.
      If I upgrade from 17' to 19', and set the reso at 800x600, will i still have the same prob? - huge webpage and needing scrolling?
      • seanc
        • Nov 2008
        • 1319
        Yes, you should have the same problem with any monitor set to 800x600.
        Do you find it difficult to read higher resolutions?
        1024x768 should be the absolute minimum nowadays.
        • gdement
          • Jan 2007
          • 690
          Try going to a higher resolution, but increase the font size to compensate.
          In windows:
          control panel->display properties->appearance->font size
          don't know how it's done on Mac.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            For web pages monitor settings don't have much to do with it the way you seem to be thinking.
            For some web pages it doesn't matter how big the monitor is...
            Web pages can be coded to be:
            .... x-many pixels wide ..or.. x-many % of screen width.
            If the page is coded for a set number of pixels and that width is more than your resolution is set for then you will have to scroll.
            - Pages that are coded that way these days are often wider than 800 pixels but rarely wider than 1024. About the only time you see pages coded wider than 1024 is if the coder has an extra wide screen and is an idiot that doesn't realize not everyone else sees what he does on his own screen.
            Mann-Made Global Warming.
            - Dr Seuss
            • turmix
              AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
              by turmix
              Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
              The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
              At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
              During another reassembly, I made a mistake, and...
              01-29-2024, 03:48 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
              by momaka
              03-15-2023, 10:17 PM
            • abajor
              A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
              by abajor
              Having this very weird issue.
              The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
              I swapped with a working screen from an A2141 waiting for parts.
              The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
              The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
              04-27-2024, 01:37 PM
            • 3D Modelka
              AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
              by 3D Modelka
              Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
              02-09-2024, 02:42 AM
