Capacitance Meter?
+ More Options
Posts
  • Bishop
    • Apr 2009
    • 99
    Capacitance Meter?
    I've been reading the post here tonight and really enjoy this forum.
    You guys have helped me and given me the confidence to fix things I never thought I could.
    I was reading a post and the topic was about capacitance meters. I'm retired telephone company and I used hundreds of different meters in my career, beginning with the simple analog Ohm meter.
    I currently on my second Fluke brand digital meter, after my old Robinair finally gave out after 25 years of great service.
    My question is: Can I use he Fluke 73 III digital meter to measure capacitance?
    Until I retired, Resistance was the main trouble issue I tracked down for 35 years. Some of the telephone wiring loop test that we made was at 60,000 feet of distance in the twisted wire, which was a 30,000 direct measure from a point to point. We were requred to climb the telephone poles between point to point. We would measure at one point, say 25,000 feet and guess the foot distance and climb every pole until we found the trouble.
    Only one in 150 technicians had Bucket Trucks to use, I was always in the 149 crowd.
    Capacitance Meter, I see lots lots sale on the internet, but most look like my Fluke 73III
  • PlainBill
    • Feb 2009
    • 7034
    Re: Capacitance Meter?
    Wrong subforum.
    To answer your question, while the Fluke 73 III is a fine instrument, it doesn't measure capacitance. Also, while checking the capacitance is helpful, it is more important to know the ESR of the capacitors.
    Take a look at this thread, in particular the Blue ESR meter and RusMike's new meter.
    PlainBill
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Look at the capacitance range.
      For what we talk about here you need something like 0.01uF-4700uF to cover most everything.
      Most of the DMM's with an add-on Capacitance function aren't in that range.
      Mann-Made Global Warming.
      - Dr Seuss
        12-31-2023, 06:04 AM
      • Baldbentley
        repairing a Fluke 335 clamp meter
        by Baldbentley
        I am repairing a Fluke 335 clamp meter. After contacting fluke it appears there is no service manual or circuit board/ component list available. I have determined that there us a faulty PNP bipolar junction transistors shown in the pictures. I am having trouble sourcing this transistor. I pulled a good one off of the board and tested it with my component analyzer but I cannot find anything that matches the specifications. Any help locating this part or a replacement would be greatly appreciated.
        Thanks...
        10-18-2023, 02:05 AM
        HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
        This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
        09-12-2024, 02:00 PM
      • Nick Nougat
        Siemens Gigaset DA810A landline telephone with answering machine resets every minute
        by Nick Nougat
        I'm posting this here since there does not seem to be a more fitting category.
        The Device
        The Gigaset DA810A is a landline telephone with an LCD screen, an answering machine and integrated telephone book. I have the version for the European (i.e. German) market.
        It has two separate modules that can operate independently of each other: One is the basic telephony part that always works and is powered by the DC voltage coming through the telephone wire. It relies the TEA1110A telephone transmission and dialler chip for that.
        The 'smart' part of the phone with the answering...
        04-01-2024, 04:00 PM
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
