Dell u3014t flashing green pixels
  • blueboxer
    • May 2020
    Take a look at this video for a better idea: https://i.imgur.com/hDnTckc.mp4
    It started a while ago. In the beginning it would be only small portions of the screen, and then as the screen warmed up it would go away, but recently it covers the whole screen and no longer goes away. If the input is black it sometimes doesn't happen, but as you see in the video, if theres a bright pixel, the green pixels after it will light up. And not all of them, its every nth one. If the resolution is lower, the green pixels are farther apart. It happens on all inputs (cdmi, DisplayPort and dvi). Interestingly, it doesn't happen to the onscreen menus, those are pristine and don't cause streaking either. So I suspect the panel itself isn't the issue, but something to do with the mainboard itself. I Took a look at it but none of the large caps seemed off (if that even is the issue). I'm not sure if what else I can look for.
  • HTR-Informatique
    Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
    by HTR-Informatique
    YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
    I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
    On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
    I also changed the screen because the PC fell and the screen was broken.
    I changed the battery with a new and original battery.
    I also had corrosion/oxidation on the...
    02-09-2025, 06:51 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • YellowJacket
    DELL Latitude 5410 - dead; pwrbtn flashing
    by YellowJacket
    Hi folks,
    DELL Latitude 5410, board number FDZ41 LA-J371P Rev: 1.0 (A00), schematic uploaded in different post, here is the link --> https://www.badcaps.net/filedata/fetch?id=3484415
    When I connect it to a power ( DELL round charger, or USB-C ), LED on the power button starts flashing white, and the laptop doesn't do anything ( flashing slows for a very brief time in time when I press it, but it continues again ). Battery is not charging. While the charger is connected, I have few voltages present, but some of them are fluctuating, see attached pictures.
    All I was able...
    04-26-2025, 07:05 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
