Samsung Syncmaster T220 problem
  • JohnNovak
    • Nov 2018
    • 72
    • Slovenia
    Hi.
    New problem with monitor Samsung Syncmaster T220.
    Monitor works fine for months, it is used monitor.
    Today is start to show brightness and is adjusted to 100 with not pressing any right side buttons.
    Picture also goes black for 0.5 seconds every 5 seconds.
    Probably need to check power board caps?
    Any experience with this problem?
  • R_J
    • 9594
    Re: Samsung Syncmaster T220 problem
    Use the SEARCH▼ above, there are lots of threads on this model, and it IS likely bad capacitors.
    • JohnNovak
      • Nov 2018
      • 72
      • Slovenia
      Hi.
      To open this monitor is nightmare.
      I check capacitors are OK.
      I can not found any problem about OSD display issue here.
      • CapLeaker
        Leaking Member
        • 8331
        maybe something is jammed in the buttons?
        • JohnNovak
          • Nov 2018
          • 72
          • Slovenia
          I also check this option, jammed buttons.
          No any switch was jammed. One switch was a little tired when i compare to others.
          I replace this switch. Multimeter readings show no any problem with switch.
          The most important was pcb cleaning i think.
          But still monitor housing need to be open, some service manuals should be used for opening this housing with
          14 hidden clips.
          Horrible Samsung monitor, easy to assemble almost impossible to disassemble without damaging the clips.
          No any bad capacitor was in power board, all OK.
          I found some manuals to help to open this housing.
          Not so easy to open like picture show.
          I check monitor for 3 hours with open back cover, no faults was present.
          Now when monitor is assembled the fault is back, blinking back light, some OSD problem again, brigthness goes to 100.
          Still not solved.
          • JohnNovak
            • Nov 2018
            • 72
            • Slovenia
            Hi.
            Anybody can help with this problem?
            Thank you.
            • CptChronic
              Samsung LU32J590UQUXEN Monitor display problem
              by CptChronic
              I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
              Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
              But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
              04-24-2023, 04:33 PM
              09-07-2024, 05:50 AM
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • alro7779
              Samsung UN55MU6103F video problem; has colored stripes on the display
              by alro7779
              Hello, everyone!
              A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
              09-27-2025, 11:29 PM
            • soopacrucial
              by soopacrucial
              Hi folks,
              10-29-2024, 02:40 PM
