Samsung Syncmaster T220 problem
  • JohnNovak
    • Nov 2018
    • 73
    • Slovenia
    Hi.
    New problem with monitor Samsung Syncmaster T220.
    Monitor works fine for months, it is used monitor.
    Today is start to show brightness and is adjusted to 100 with not pressing any right side buttons.
    Picture also goes black for 0.5 seconds every 5 seconds.
    Probably need to check power board caps?
    Any experience with this problem?
  • R_J
    • Jun 2012
    • 9775
    • Making Money
    Re: Samsung Syncmaster T220 problem
    Use the SEARCH▼ above, there are lots of threads on this model, and it IS likely bad capacitors.
    • JohnNovak
      • Nov 2018
      • 73
      • Slovenia
      Hi.
      To open this monitor is nightmare.
      I check capacitors are OK.
      I can not found any problem about OSD display issue here.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8887
        maybe something is jammed in the buttons?
        • JohnNovak
          • Nov 2018
          • 73
          • Slovenia
          I also check this option, jammed buttons.
          No any switch was jammed. One switch was a little tired when i compare to others.
          I replace this switch. Multimeter readings show no any problem with switch.
          The most important was pcb cleaning i think.
          But still monitor housing need to be open, some service manuals should be used for opening this housing with
          14 hidden clips.
          Horrible Samsung monitor, easy to assemble almost impossible to disassemble without damaging the clips.
          No any bad capacitor was in power board, all OK.
          I found some manuals to help to open this housing.
          Not so easy to open like picture show.
          I check monitor for 3 hours with open back cover, no faults was present.
          Now when monitor is assembled the fault is back, blinking back light, some OSD problem again, brigthness goes to 100.
          Still not solved.
          • JohnNovak
            • Nov 2018
            • 73
            • Slovenia
            Hi.
            Anybody can help with this problem?
            Thank you.
            • Eures
              • Apr 2026
              • Italy
              Hi, I'm having the same problem with my T220 and you described exactly what's happening, did you fix it?
              • Eures
                • Apr 2026
                • Italy
                For me the problem was solved: I replaced the small electronic board located under the buttons..
                • JohnNovak
                  • Nov 2018
                  • 73
                  • Slovenia
                  The main problem with this monitor was on and off power supply. The power was constantly shut off. I found the problem. It was optocoupler in power supply.
                  Now works again. It was impossible to find fault by measure this component, just replace solve the problem.
                  • Boardview and Schematic Bot
                    Samsung Galaxy Tab S / E SM-T805W SM-T800 SM-T378V SM-T805W Schematic & Boardview
                    Samsung Galaxy Tab S / E SM-T805W SM-T800 SM-T378V SM-T805W Schematic & Board View
                    Samsung Galaxy Tab S 10.5 SM-T805W.sch.pdf
                    Samsung Galaxy Tab S 10.5 SM-T800.pdf
                    Samsung Galaxy Tab E 8.0 SM-T378V.pdf
                    Samsung Galaxy Tab S 10.5 SM-T805W.bv.pdf...
                    09-29-2026, 10:33 AM
                  • CptChronic
                    Samsung LU32J590UQUXEN Monitor display problem
                    by CptChronic
                    I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
                    Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
                    But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
                    04-24-2023, 04:33 PM
                    09-07-2024, 05:50 AM
                  • howardc64
                    Samsung UN55JU650DF network/streaming problem
                    by howardc64
                    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                    07-09-2025, 12:44 PM
                  • keepread
                    Dell monitor PSU vs Dell laptop PSU
                    by keepread
                    Hi there!
                    Someone gave me their old monitor, it's Dell S2715ht.
                    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                    10-30-2025, 04:45 PM
