acer AL1914 TFT (capacitor C0535)
  • carlosprettyboy
    • Oct 2009
    • 16
    Can anybody help?
    The capacitor C0535 from my monitor acer al1914 blow up after a powercut in my house.
    I am finding it hard to identifying the expecifications of the capacitor for me to be able to order it, and from where can i buy it.
    Here is a picture of the monitor power supply taken from a chines website.
    The one that blow up its the big black one on the right
    I apreciate the help
    thank you in advance
    Carlos Gomes
  • Bobdee
    • Jun 2008
    • 461
    Re: acer AL1914 TFT (capacitor C0535)
    Hello Carlos
    Dont be to hasty with that capacitor, chances are there are a few more components that may have been taken out, eg mosfet or bridge rectifier and input fuse
    Pictures of top and bottom of your board will be needed to get the best help for you
    Maybe a kind MODERATOR will put this thread in the Monitor Forum where it will get better exposure and more help, please
    bob
    • carlosprettyboy
      • Oct 2009
      • 16
      thanks for your reply Bobdeee, i will take some pictures today and post it.
      In another hand i have contact a company to sell me the all power supply just watting for some prices.
      Thank you again
      Carlos Gomes
      • carlosprettyboy
        • Oct 2009
        • 16
        Can anybody help?
        Here is a picture of the monitor power supply.
        Carlos Gomes
        • Bobdee
          • Jun 2008
          • 461
          When you said it blew, I thought you meant in bits and burned that you could not identify
          Just ease glue away from cap and stand it up, you will find the info you need on it, they are normaly a G/Purpose 100uf 400V
          • carlosprettyboy
            • Oct 2009
            • 16
            Hello bobdee,
            I dont understand what you mean with ease glue away from cap and stand it up.
            Do you think theres any more components broken apart from the capacitor?
            Its the info that you can see on the side of the capacitor the one that i need?
            • Bobdee
              • Jun 2008
              • 461
              Originally posted by carlosprettyboy
              Hello bobdee,
              Info on other side of cap is what you need
              Will take a good look at pics in about half hour or so, get back to you
              • Bobdee
                • Jun 2008
                • 461
                I have had good look at pics and I dont see any thing out of the ordinary
                That cap rarely goes under normal circumstances but you may be lucky and find its only the cap thats gone
                Was the fuse gone???
                I suggest you check bridge rectifier and mosfet for shorts
                • carlosprettyboy
                  • Oct 2009
                  • 16
                  Hello Bobdee,
                  Here is a pic of the other side of the capacitor.
                  Thank you for all your help.
                  Waitt for your reply
                  Carlos Gomes
                  • Bobdee
                    • Jun 2008
                    • 461
                    Hello Bobdee,
                    Carlos Gomes
                    Im not good on replacment caps others in the forum are
                    Yours is Elite 82uf 400V 105C PW series (probably general purpose)
                    You can put a 100uf 400V 105C G/P in there for replacement you seem to have room
                    Can another member suggest a replacement cap please
                    • carlosprettyboy
                      • Oct 2009
                      • 16
                      Hello Bobdee,
                      I cant find exactly the same model that i need but i did found 100uf 400V.
                      Know i hope somebody can tell me if theres is no problem on puting that one insted.
                      Thank you
                      Carlos Gomes
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        Hello Bobdee,
                        Thank you
                        Carlos Gomes
                        Go for it. Not a big difference (18uf).
                        • ASUS ROG Maximus IX Code
                        • Intel Core i5-7600K 3.8GHz
                        • Windows 10 Pro x64
                        • GeForce GT1050
                        • Toasty
                          • Jul 2007
                          • 4171
                          Ripple handling should be 500mA or better. Original PW is rated 500 or 520mA depending on diameter of can. 16 or 18 mm.
                          From digikey.com - both of these are 18mm diameter. Measure to be sure you have the clearance for them.
                          UCC KXG - 18 x 25mm, 610mA:
                          http://search.digikey.com/scripts/Dk...me=565-1468-ND
                          or
                          Panasonic EE - 18 x 31.5mm, rating @ 120Hz not given. Following the KXG example though, I would surmise about 650mA:
                          http://search.digikey.com/scripts/Dk...name=P13669-ND
                          Toast
                          veritas odium parit
                          • carlosprettyboy
                            • Oct 2009
                            • 16
                            Hello toasty,
                            Thank you for the reply.
                            I am not an expert on this field, i can replace the capacitor but i need to know the exact model that i have to buy.
                            If you can tell me the exact model the i have to buy that will work i will be very apreciated.
                            Best regards
                            Carlos Gomes
                            • EGuevarae
                              • Nov 2008
                              • 1336
                              Hello toasty,
                              Best regards
                              Carlos Gomes
                              Look for the size in the one you have, then look the size of the two Toasty suggests.
                              • GeForce GT1050
                              • Toasty
                                • Jul 2007
                                • 4171
                                From PM - Yes, you can use a 100uF there. Do you already have it? Is that why you continue to mention it?
                                The 2 I gave you above are the correct value and rating for the ripple current, according to the one that was there. If you choose to use a/the 100uF there, then let us know 1st its brand and series so we can verify its fitness for use here.
                                Measure the diameter of the old cap and report.
                                Toast
                                ...is there an echo in here...?
                                veritas odium parit
                                • carlosprettyboy
                                  • Oct 2009
                                  • 16
                                  The diameter of the old cap its 18x31mm
                                  Carlos Gomes
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    Again in PM -
                                    Hello Toasty,
                                    No i dont have it yet i just thought that on the retail shop near me they will only have the 100uf 400v but i will only know that friday when they are open.
                                    Can you tell me what the echo is?
                                    You ask me for the echo but i dont know what it is.
                                    The mesure is 18x31mm.
                                    Best Regards
                                    1) Please stop the PM's. It helps everyone here if you post and ask questions here.
                                    2) If the local shop has them then you'll need to get the brand and series of the cap from them and post the information here for someone to review. No sense buying something that won't be correct for your power supply.
                                    3) 18x31mm is fine and either cap I linked will fit. It also means that the PW series was the 520mA ripple variety.
                                    4) The echo was it seems like I was/am repeating myself. Perhaps the humor is lost...
                                    Toast
                                    veritas odium parit
                                    • carlosprettyboy
                                      • Oct 2009
                                      • 16
                                      Hello Toasty again,
                                      1- Thank you for your help.
                                      2- I am not an expert on electronic (not even close)
                                      3- I am not english i am spanish (thats why i didnt understand echo or PM)
                                      now i know.
                                      4-I dint mean to annoy you by sending PM i dint knew that was a problem.
                                      (but i understand what you mean ist better to post it here so everybody can help and be helped)
                                      5-Its the first time i register myself in a forum.
                                      6-I was juts triyng to save some mooney insted of sending the monitor to fix and be charge allot of monney.
                                      7-You ware a big help, every one of your coments was very helpfull and i never ment to ofend you in any way.
                                      If i cant get the cap on my near retail shop i will order it from the links you give me problably the panasonic one witch seems to be the best option.
                                      Thank you once again Toasty
                                      Best Regards
                                      Carlos Gomes
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        Well then, Welcome to the Forums!
                                        Where are you located? If you put that information in your profile (there is a spot for it), it helps us help you.
                                        Toasty is usually rough around the edges/grumpy/cranky. Pay him no attention when he's like that...
                                        Toast
                                        veritas odium parit
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Aspire A317-33-C5RE + Pack Gold Acer 17'' Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A317-33-C5RE + Pack Gold Acer 17'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-33-C5RE + Pack Gold Acer 17'' boardview and A317-33-C5RE + Pack Gold Acer 17'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 03:10 AM
