HP w2007 PTB-1773 - Where to start?
+ More Options
Posts
  • MegaOne302
    • Apr 2009
    • 94
    #41
    Re: HP w2007 PTB-1773 - Where to start?
    Originally posted by maverick530
    Am I supposed to be measuring DC or AC Voltage at that point? If I place my meter on setting 'DC 2 V' (labeled in photo as 1) the reading goes all over the place plus and minus a few millivolts. If I place it on setting 'AC 200 V' (labeled as 2) it registers at most a .5 for a split second then zeroes for most of the pins. If I release the ground (black) it tends to stay at .5 but not sure that's a valid reading.
    Am I doing it right? What does this mean?
    The meter is set to read amperage not voltage. Move the Black test lead to the center/common socket. And the Red test lead to the voltage socket.
    Does an idiot make a sound if no one’s there to hear them talk?
    • maverick530
      • Dec 2008
      • 107
      #42
      Originally posted by Bobdee
      Can you check the dual diode on heatsink, board number D809
      check Solder first if ok then remove and check pins 1 + 2 with diode function both ways, you should have a reading only one way and infinity the other
      Repeat the procedure on pins 2 + 3
      I will get back to you on the P/Supply flow info, as soon as I can find it
      Checked D809 & D810 (while I was at it) and both register a value in only one direction and infinity the other. I suspect these are good.
      What's next?
      • maverick530
        • Dec 2008
        • 107
        #43
        This has been corrected as you suggest a while ago, thanks for catching this too.
        • Mike7168
          • Jul 2009
          • 8
          #44
          I have the service manual for HP W1907 which uses the same inverter board,
          I can upload the PDF copy if you are interested. Thanks
          • maverick530
            • Dec 2008
            • 107
            #45
            Yes please, I'm very interested if it will have any more information on how it can be fixed. Thanks,
            • Bobdee
              • Jun 2008
              • 461
              #46
              What's next?
              Have just browsed over the whole thread again and its not clear to me as to whether this P/Supply has been recapped as Plainbill suggested
              ??? Can you confirm as to whether it has been Recapped or not as the case may be ???
              THXs
              • Mike7168
                • Jul 2009
                • 8
                #47
                Tried to upload the service manual last night but the file is too big 3mb, I can email to you. Please email me your address to mselvam1408@yahoo.com.sg.
                • maverick530
                  • Dec 2008
                  • 107
                  #48
                  THXs
                  I have not recapped the board yet, although I have purchased all capacitors to do so. I did, however, remove the suspected 2.2uF CapXcon (C828?) and tested its capacitance and it registered fine on a capacitor tester, so I resoldered it back.
                  I didn't want to recap the whole board just yet because we suspected the MOSFETS on the inverter side were shorting things out. I realize caps can still be bad even though they pass visual inspection, but all of them pass visual inspection. Is there ANY way to test the caps on-board, such as checking the voltage across them when powered like we did with the huge one (C805)?
                  Is recapping the whole power side of the board the next step? After all, remember, there was never any light on the controls--I'm not getting ANY power out of the board, so I'm pretty confident the problem resides on the power side...
                  • Mike7168
                    • Jul 2009
                    • 8
                    #49
                    Please see attached service manual page 37 - 42 for power problem.
                    • Bobdee
                      • Jun 2008
                      • 461
                      #50
                      The trouble with good visual caps is they can still be bad, as you have said above
                      The trouble with good capatance caps is they may still have bad ESR
                      I am with you, I do not like recapping when you cant see any visual bad signs on the caps, seen Threads where members have done a total recap and still find that it made no diffrence to there problem ( they must feel sick )
                      However like you I convinced that its the P/S that is problem, but I suspect that other members thought that you have done a recap or at least the caps that Plainbill sugested (the 3 he circled in red) so I think there some misunderstandig possibly
                      I would recap plainbills 3 and try it out, if no joy replace the other small one right side of transformer and the 3 big ones by P802 connection and try it out again, If that dont do it recap the rest that are on the P/S side
                      At least then caps are eliminated if it still dont work
                      Then I am sure you will then get help with probing the Voltages
                      • maverick530
                        • Dec 2008
                        • 107
                        #51
                        Thanks to Mike for this very similar service manual for the HP w1907. I've also attached a very relevant power/inverter board overall schematic. I think it's brilliant and I would do well to study it.
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          I agree with Bob. You had been suggested to replace three caps, and that'ts easy, and would not hurt if they were good (as Bob said and we have found more often than not, even if capacitance is OK and no visual damage is found, ESR can be high and that's the same if not worst than a capacitance difference). Change at least the three caps and start from there.
                          • ASUS ROG Maximus IX Code
                          • Intel Core i5-7600K 3.8GHz
                          • Windows 10 Pro x64
                          • GeForce GT1050
                          • maverick530
                            • Dec 2008
                            • 107
                            #53
                            Sad day,
                            I replaced all of the caps on the power side and still no joy.
                            Measuring the voltage across the outputs (with the black ground on the corner screw area) results in a -0.33 v to -0.34 v oscillation.
                            What else can I try/probe?
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Sad day,
                              That negative oscillating voltage is intriguing. A positive voltage would indicate the SMPS is starting, but shutting down. A negative voltage??? Do you have an actual schematic of the power supply / inverter. The block diagram doesn't help a lot.
                              PlainBill
                              • maverick530
                                • Dec 2008
                                • 107
                                #55
                                Attached are the actual schematics for the w1907 power supply (Hopefully, functionally similar to the w2007, because they sure are laid out differently).
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Well, let's give it a try. The SMPS controller in the schematic is IC901, a LD7552BPS. It should be one of two ICs on the board. Check the voltage from pin 1 (Gnd) to pin 3 (Vcc) with AC power connected. It should be nearly 20 volts.
                                  PlainBill
                                  • maverick530
                                    • Dec 2008
                                    • 107
                                    #57
                                    PlainBill
                                    Assuming pins 1 and 3 are the bottom left pin and 3rd one over from the bottom left (when looking at the IC with the lettering right-side up), I get 0 volts. Sometimes I get 0.01 or 0.02 but really nothing.
                                    Checked the voltage across C805 and I still get 160 volts just as a quick sanity check that I am getting power to the board and my DMM is on and plugged in correctly, but still nothing across pins 1 and 3 of this IC.
                                    Just for kicks, I stuck the negative probe to the screw ground in the corner of the board, and then the red probe on pin 3 and I get 3 volts to 4 volts then -1 and it kinda goes crazy, but I got something. Not sure if this really is accurate but just thought I'd throw that out there.
                                    Does this mean it's bad?
                                    • maverick530
                                      • Dec 2008
                                      • 107
                                      #58
                                      Also, I wanted to make sure, that this was the chip (circled in red)? It has the right number of pins and it says I801 by it (not IC801, same thing?).
                                      From what I can make out the IC reads:
                                      CA 1530A
                                      651D202
                                      MnG7311
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        CA 1530A
                                        651D202
                                        MnG7311
                                        Maverick,
                                        It appears this is a radically different power supply board. The most likely part number for the SMPS controller is TEA1530AT. By the way, I have a large magnifier I use to determine part numbers. Even then, it is tricky.
                                        In any event, the first thing to determine is the power supply to the SMPS controller. I've attached an edited version of the picture, check the voltage between the two circled points.
                                        By the way, don't use the metal chassis as a reference when measuring voltages on the line side of an SMPS. I just spent a few minutes trying to figure out what the wave form would be and got a headache.
                                        PlainBill
                                        • maverick530
                                          • Dec 2008
                                          • 107
                                          #60
                                          Maverick,
                                          PlainBill
                                          That measures 160.1 v.
                                          • EVXIO
                                            Z83-V BIOS needed (Board Sticker Z85-D3X8-G-V1.2-Z8350-4G+64G)
                                            by EVXIO
                                            Beelink/AZW drop Z83 support for this device.
                                            I need BIOS for AZW Z83-V.
                                            Sticker code: Z85-D3X8-G-V1.2-Z8350-4G+64G
                                            Board code: Z85-D3X8-V1.2
                                            Known working bios version Z85_0303 X64
                                            filename: Z85_D303_Z83-V_AZW_window_NoPowerON0428.bin
                                            Thank you in advance!
                                            01-11-2024, 03:41 AM
                                          • jlum1951
                                            HP w1907 2007.01.15 ILP1-027 troubleshooting
                                            by jlum1951
                                            I've been struggling to find a schematic for a pesky HP w1907 monitor. Sometimes it flickers, sometimes it reverts to a 2 seconds to black. I have opened it up more times than I care to remember, reflowed solder, or switched lamps around and it magically may seem fine, then I put it back together and it will misbehave again. Some have replaced lamps but this can all the lamps suddenly go bad?
                                            The power board marked as 2007.01.15 ILP1-027. It seems there are schematics for the later versions but they seem to be totally different. One thing I want to bring to the attention of this...
                                            02-26-2021, 12:06 PM
                                          • blaster_
                                            Samsung UE49MU6105K - boot loop, horizontal lines
                                            by blaster_
                                            Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                            Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                            06-22-2022, 05:19 PM
                                          • kitor
                                            HP Pro Mini 400 G9 - Led code 3/6 Processor does not support an enabled feature / disable AMT in dump?
                                            by kitor
                                            Hey,
                                            I got HP Pro Mini 400 G9 waiting for a long time for a CPU. Bought I3-12100T which is on supported list just to receive code 3,6 which says "Processor does not support an enabled feature".
                                            After research I found this is most likely due to all the management stuff being enabled in BIOS (it has vPRO essentials I5 sticker so that is very likely) where 12100T definitely does not support it.
                                            Unfortunately I wasn't able to find any friend who would have and lend me their CPU to fix that... so the question is, can this be changed at bios dump level?
                                            I attached...
                                            02-03-2025, 11:09 AM
                                          • ClockChip
                                            GE 7-4643A Clock radio - Is this a common pictogramme for 9-volt battery backup on appliances?
                                            by ClockChip
                                            I came across this sticker recently:
                                            (It's from a 1980s GE clock radio - the model number is at the bottom left.)
                                            I worked out the top pictogramme (indicating a 12/24 hour facility) and bottom pictogramme (120v or 220v mains power) fairly quickly. But the middle pictogramme...ah. That one left me baffled for a time.
                                            (I won't say how long, exactly, because it would be too embarrassing.)
                                            Eventually, it dawned upon me that this was a pictogramme to indicate a 9-volt battery backup facility.
                                            My question is: has anyone...
                                            08-27-2024, 09:02 AM
