Hi guys, have a HL248 that was going black or I'm thinking scramble lines sometimes. Sometimes it would work fine but seemed like code on a page would make it fail. Other times straight to black. It's been in storage a while and pulled the boards before trying again so going off memory.
I've heard of a successful fix on this monitor just replacing the caps. My problem is I'm trying to figure out the best caps to put in it that will fit. None of mine look bad. Has anyone had similar problems and fixed one of these yet?
The board with a single cap has a low impedance FOAI FZD 47uf 63v.
Data sheet www.chinafoai.com/ep24.htm
Easy enough and looks like digikey has panasonic FC or nichicon UPW that would work. Which would you recommend?
The other board has 3x FOAI CD11XH 220uf 16v and 3x FOAI CD11XH 100uf 16v.
Data sheet https://cdn.badcaps-static.com/pdfs/...87cf6f3f17.pdf
Now this one has a height restriction of 9mm but up to 10.5mm may be able to fit with some finessing.
The only options I'm seeing are URZ and ML for the 220uf and GA, URZ and UTT caps for the 100uf. Which would you recommend?
