LG IPS277L - Cycles/backlight on-off
  • djdblaster
    • Sep 2017
    • 16
    I've got this monitor that turns on for blink of a second, then turns off, then on, then off and so on.
    I've disassembled the whole screen, took a look at LED strip, replaced 3 LED's, but the backlight still doesn't work properly.
    LED strip is divided into 4 sections (AB + CD). Bad LED's that were replaced were 2 LED's in section C (1st and 2nd LED) and in section D (1st LED).
    First LED's in each section have a Diode symbol written above.
    When those 3 LED's in sections C and D are removed and I try to power up the board with LED strip connected, then sections A and B work, backlight stays on.
    What I have now is all LED's installed and I tried to connect the laptop through HDMI ports. One of the ports works fine, the connection is stable, while other port keeps connecting and reconnecting. Backlight keeps flashing on both ports. I haven't tried with LED's removed in sections C and D.
    Before disassembly, I tried to see if anything could be displayed at the monitor while the laptop was connected through HDMI and it does. The screen was visible in the moments when backlight flashed.
    I've also measured HDMI ports using resistance mode (diode mode?) and one pin had 0.880 while on the other port, the same pin had around 0.550.
    Forgot to say the capacitor where voltage for LED's goes has around 19.5V when backlight is off and around 40V when backlight flashes.
    If you need any pictures, numbers, let me know.
    I'm not an expert, rather a noob, still learning.
    I appreciate any idea/comment.
  • pni
    Backlight panel diffuser melt by backlight leds broken
    by pni
    Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
    10-12-2025, 12:08 AM
  • edugimeno
    (old) LG 32lk330 cycles Backlight 3 times and then OFF
    by edugimeno
    Hi!! I have been given this old TV set.
    When I hit the power button, the BL (as you know this is a CFL backlight) turns on, video works fine as I can see the LG logo show off, but the backlight starts going on-off for 3 times, when it gives up and turns completly off
    This set has a inverter board on the top right corner. This inverter (or the tubes, I don't really know) buzzes very loudly during the second that the BL stays ON. I have posted a video, turn your volume UP!
    https://fileport.io/9EdfmD5qtEaw
    I have checked voltages at the PS
    All normal voltages...
    12-11-2023, 01:28 PM
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • hollox123
    ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
    by hollox123
    Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
    1. Laptop keyboard doesn't work
    2. The backlight on the laptop keyboard doesn't work
    3. The x2 side LEDs (red) on the laptop don't work
    The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
    I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
    But I am strongly aiming that it is somehow a BIOS-related problem,...
    05-11-2025, 08:05 AM
  • signal.quest
    Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
    by signal.quest
    I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
    03-17-2024, 10:14 AM
