Acer AL718: It Goes On And Off
  • nick2012
    • Nov 2013
    • 40
    • NL
    Re: Acer AL718: It Goes On And Off
    It go's true its old cycle LED and Lamps on off,this time I could hear some hissing noise
    frome the Inverter side ?
    • nick2012
      • Nov 2013
      • 40
      • NL
      edit double post.
        OK, something in the inverter circuit is the cause of the problem. Try it again in the real dark room to see if you can see any arching/sparking around the inverter section, also check the pin of the lamp sockets on the board to make sure it does not have bent pins.
        BTW. can you also smell Ozone?
        • nick2012
          • Nov 2013
          • 40
          • NL
          No ozone smel,and no sparklins ,no bend pins in the lamp sockets also.
          • nick2012
            • Nov 2013
            • 40
            • NL
            the hising noise is gone .
              But the LED is blinking still, some thing in the inverter circuit for sure is bad. BACKLIGHTS come on?
              I need to know if the backlights even flash on or not, I am suspecting either bad inverter transformer or bad dual MOSFET's (8-pin device next to the inverter transformer).
              • nick2012
                • Nov 2013
                • 40
                • NL
                #27
                yeah stil blinking his orange/bleu cycle ,and backlichts come on as the Led is bleu and
                go off when Led is Orange.
                • nick2012
                  • Nov 2013
                  • 40
                  • NL
                  #28
                  can you point out the inverter transformer or bad dual MOSFET's on the picture,and how
                  to check then for error,i'm a' eletronics specialst just a' low grade basic Eletricity paper for
                  home,however I, can measure with the multimeter and have a'solder iron,And now the
                  basic components to identefy like the Caps and resistors,I have also checkt the inverter
                  IC's for shortings but they where fine.
                  Regards
                  Nick
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    Your pics are not really big/clear enough for trouble shooting.
                    Inverter transformers are the large black rectangular components
                    with the white label on top. and the mosfets are the 8 legged components
                    close by.
                    For testing I suggest you read the 2 seconds to black sticky at the beginning of this forum - click on trouble shooting computer displays (above centre) almost all are power off tests. start at post19
                    Also try and get the part numbers off the mosfets and look up the data sheets.
                    • nick2012
                      • Nov 2013
                      • 40
                      • NL
                      #30
                      okay will try the transformers and the Mosfets(the IC's are the 8 legged) ,
                      I will the 2seconds sticky ,and post19,I'also will look at the part nunbers.
                      thanks
                      • nick2012
                        • Nov 2013
                        • 40
                        • NL
                        #31
                        its way to dificult for me,
                        As alternite I'found that it may be beter to buy a' replacment board at:
                        http://nl.aliexpress.com/item/ViewSo...944393283.html
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4476
                          • Italy - Milan
                          #32
                          Don't do this i say, almost before exctracting the light tubes from the lcd panel and check for burning on the terminals or darkened ends..
                          "i'm a' eletronics specialst just a' low grade basic Eletricity paper for home"
                          What do you say?
                          • nick2012
                            • Nov 2013
                            • 40
                            • NL
                            #33
                            Okay i'l wont order yet then,I'will inspect the tube's for burnings,
                            I'have yesterday resolder all the major joints and have swiths the black inverter blocks
                            to see if that would make a'diference ,but it wouldent did so.
                            • selldoor
                              Slow Learner
                              • 7870
                              #34
                              OK I see that with the language problem the 2 sec to black may be hard to follow.
                              To test the inverter transformers see the picture.
                              No Power to boards. Set Meter on ohms 2000.
                              Test S1 to S2 and S3 to S4 and post results
                              • nick2012
                                • Nov 2013
                                • 40
                                • NL
                                #35
                                I'have disassembled the display and made pictures off the tubes,they are as I'can see so
                                far good exept for the ends they are litle black at the ends.
                                what do you think are they good ?
                                • nick2012
                                  • Nov 2013
                                  • 40
                                  • NL
                                  #36
                                  Thankz will try that later on,my head needs some relaxing for now
                                  Reagards
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #37
                                    They look good to me - need to be careful putting them back
                                    Some Acers did have a problem with the wires detaching from the bulbs
                                    but yours look ok.
                                    Just read your post - yes its a hard job taking lights out. If you can
                                    keep them safe you can test them again out of the frame to listen or look for
                                    any arcing.
                                    • nick2012
                                      • Nov 2013
                                      • 40
                                      • NL
                                      #38
                                      Oeps I'have putting all all back in place
                                      But will first measure the voltages on the powerboard,after that i'l disamble the display
                                      again for furter inspecktion then.
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        I would leave it if its back together - too much chance of breaking glass
                                        • nick2012
                                          • Nov 2013
                                          • 40
                                          • NL
                                          #40
                                          At S1 & S2 I' get .471 .
                                          At S3 & S$ I' get .473 .
                                          Meter on 2K
