Dell P2715Q monitor image issue
+ More Options
Posts
  • turnma
    • Sep 2018
    • 6
    My monitor is just over three years old and has suddenly developed a problem where all it does is showing a flashing vertical/horizontal image (see below) that pulses about 5-6 times per second. This is without any input cables attached. If I press buttons on the monitor to enter its diagnostics mode, which apparently puts various colours on the screen, then I can see the white parts of the image do change colour but other than that it looks the same.
    I've searched images across loads of sites and can't find anything similar. Any ideas? I did open it up and nothing looks obviously wrong, but I don't really know what I'm looking for. The only thing I did spot is that the larger capacitor in the image below has the visible lines on top of it (the smaller ones don't) but I can't see any obvious bulging.
    Thanks for the help
    Mike
  • ulyanoff
    • Jun 2016
    • 12
    • Ukraine
    Re: Dell P2715Q monitor image issue
    I think problem problem is on the t-con lcd panel (panel type ? chip dc/dc converter?). Carefully remove the cover of the closing board t-con, you need to measure the voltage of the control points VGL, VGH, VDD, etc... Signal at the monitor input must be present. Also inform about ic type on the t-con board.
    • turnma
      • Sep 2018
      • 6
      Thanks for the response. The panel is an LG LM207WR2 SPA1, or (SP) A1 as it's stated in other places. Chip appears to be Parade DP667. If the fault is within this area then is this even fixable, or at least fixable without a lot more skills than I have?!
      • ulyanoff
        • Jun 2016
        • 12
        • Ukraine
        Sample of control point from t-con. Send maximum info from your multimeter
        • turnma
          • Sep 2018
          • 6
          Sorry, multimeter problems so this took a while!
          I can't find a specific VCC point, just lots of VCC with numbers after, e.g. VCC1033/VCC12.
          For the others:
          VDD - between 7-8V
          VGH - about the same
          VGL - 0.9V
          thanks
          • ladz
            • Nov 2016
            • Usa
            Found this thread by searching for Parade DP667.
            I have one of these monitors too, the symptoms are pretty similar, ghostly white vertical lines and no/little image, but mine is 100% failed rather than intermittently failed.
            I replaced both the power supply and the main PCB (found a replacement on ebay), and the symptoms remained the same.
            The PCB that is hard-attached to the panel itself has that Parade chip on it, and I assume that it's the failed part since the individual 1.2, 3.3, and 1.8 power supply sections on that board are all fine.
            I don't think there is any hope, unless that chip can be replaced somehow.
            Interestingly there is a menu that's accessible by pressing up+down while holding the power button that makes the whole screen light up with the primary and secondary RGB colors. This works, but I think it works because it doesn't require any timing.
            • jbcmd4
              • Oct 2018
              • 3
              Any fix for this I have similar issues with dell p2417h
              • chinsoon
                • Aug 2016
                • Singapore
                I got similar problem, I suspected it is the chip RT6811 on TCON having problem. I bought the chip to replace, hopefully it is the right path.
                • Duranitron
                  • Jul 2014
                  • 544
                  • Philippines
                  the lcd screen is busted...problem with acf bonding.. i have the same symptoms with my 4 year old Dell 2415Q monitor, i bought a new lcd monitor instead .. lcd acf bonding procedure cost is almost buying a new lcd panel with 3months warranty so i decide to go buy a new monitor with 2 years warranty
                  Never stop LEARNING because life never stops TEACHING!
                  • 202020
                    • Oct 2020
                    • 7
                    • Malaysia
                    Hi there, did u manage to fix the monitor after replacing RT6811 IC on TCON ?
                    • andrhouseolly
                      Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                      by andrhouseolly
                      Hi.
                      I kindly ask you to help me solve the problem.
                      Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                      The board turns on, there is no image.
                      Read more. When the power supply is connected, the front panel indicators light up briefly.
                      When you press the power button, the button indicator lights up. The board works
                      there is no image, there is no matrix initialization, there is no image on HDMI.
                      When turned on, the fans do not spin, but when they warm up they start spinning.
                      When you turn off the button, the fans spin up to full speed for a short...
                      05-11-2024, 03:14 PM
                    • SuperJames
                      Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                      by SuperJames
                      This one's a weird one, and still unsolved despite it having gone back to Dell once.
                      Specs
                      i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                      Backstory
                      I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                      10-23-2023, 04:09 PM
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • computerbacon79
                      Dell Inspiron 3480 All in One corrupt Bios issue: reaches Dell logo and stops
                      by computerbacon79
                      The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                      05-06-2025, 06:43 PM
                    • Ven
                      Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                      by Ven
                      Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                      Issue Description:
                      1. CPU Overheating to 100°C
                        • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                        • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                        • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                        • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                        • Thermal
                      02-12-2025, 03:57 PM
