Gateway fpd1730
    Gateway fpd1730
    gateway fpd1730
    January 14th, 2009
    This quote was taken from this web site WTF
    "What fails is a mini brown colored fuse on the small board that is next to the main board"
    I have no idea why this huy did not just list the part number and board number.
    Does anyone know what the "mini brown fuse is"
    Or the "small board next to the main board"
    Here is a picture of all 3 boards.
    The gateway fpd1730 monitor is so easy to fix I was surprised. What fails is a mini brown colored fuse on the small board that is next to the main board. I remove that 4 amp fuse and solder jumper leads to the connections and then install a 5 amp fuse. If this doesn't fix the problem and the screen flashes for a second there are two transformers on that same small board. What happened is the solder gets hot on these connections and when they cool off the solder doesn't give a good connection. All I do is resolder all of the leads on those transformers. I have fixed 4 of these monitors and all 4 repairs have been reliable. That inverter board is listed for sale online for 75.00 and I would say my repairs take maybe 15 minutes and you can get your monitor up and running a lot cheaper. I did buy some magnifier glasses that help me but those were only 2.00 surplus compared to 12.00 at Walmart and 18.00 at Barnes and Noble. Gateway screwed a bunch of people with this model LCD screen but since it is so easy to fix my hat is off to Gateway
    ^Learning to walk on rice paper without leaving a trace,
    Re: Gateway fpd1730
    OK.... I should have read better. He stated the board also has 2 transformers" more than beats my eye's. Jacob
      Re: Gateway fpd1730
      Quick update. I tried to jumper the fuse. Still no power at all.
        Re: Gateway fpd1730
        More than two.
        Mann-Made Global Warming.
        - Dr Seuss
          Re: Gateway fpd1730
          Better start at the beginning. Do you have power TO the inverter?
          One of the problems with the internet is that the problems and solutions are not so universal as some people claim. For example, the inverter shown in that picture is not the same as the one on the FPD1730 in my possession. Different inverters = different sets of problems.
          PlainBill
