I have issues with three different LCD boards, 2 power inverters and one logic board, hopefully someone here can help out.
Board #1 is the power inverter from an LT765. Turns on then flickers off after about 2 seconds. Replaced it with a good inverter and it works but I accidentally fried the logic board somehow so it is just all white when on now.
The second board is the logic board I mentioned above. I guess I fried it with a loose connection when I switched inverter boards, heard a high pitched noise and smelled burning and knew something was wrong. You can see the browning on the back.
Third board is from a Proview PL926, same problem as the first turns on then flickers off after a second or two. Im assuming that this is an inverter problem also. I see the browning on the board but not sure what is wrong with it. Please tell me if you need any more pictures of certain parts.
