Re: Broken Dell 1800FP Power Supply - when and when not to resolder?
This Link Ain't Working
I couldn't find the IC being sold anywhere other than Ebay, so took my chances and ordered a couple. It's coming from overseas so won't arrive for a while. In the mean time, I re-installed one of the ICs I had that doesn't show a short across pins 6 & 7 to test voltage across pins 6 & 7 when powered. Voltage measured in the milli-volts. Could some bad components upstream of the IC be causing this problem? I tested the small diode (D907) that's next to the IC off circuit; that tested fine. Also, I get around 160V out of the big capacitor, so that seems to be fine. Any suggestions?Leave a comment:
They don't sell this IC anymore. Their websites just say product's obsolete. There are still some sellers on Ebay though. But given my past experience with buying this IC via Ebay, I'm a bit reluctant to do so again.Last edited by ptmy3; 03-23-2017, 09:53 AM.Leave a comment:
Did you try Mouser and Digikey?Leave a comment:
I bought those 3 ICs from a random seller on Ebay. Do you have a recommendation of a reputable source?Leave a comment:
Well, even your brand new IC and never been installed is already showing very low resistance between VCC pin and Gnd pin, that is not good so I really do not trust what you have at this point unless you may want to buy the IC from trusted company.Leave a comment:
I replaced all the capacitors in the power supply except for the large one. I'm still getting zero volts at the output terminals. Can anyone think of anything else I can try before I give up on this power supply?Leave a comment:
I checked Q902. It wasn't shorted. Nest, I'll try replacing all the capacitors except for the big one. If that doesn't work, not sure what to do next other than to get a replacement power supply.Leave a comment:
Suggest you check Q902 for shorts (see post #59). If shorted, it can cause the chip to fail.Leave a comment:
Yes, it measured 4.4 ohms off the board. That IC is new and has never been installed. Looks like I received defective merchandise. Hopefully, the other two are still good. Guess the only thing left for me to try is to replace the remaining capacitors. Anyone have another suggestion please post.Leave a comment:
"Resistance across pins 6 & 7 on that 3rd IC only measured 4.4 ohms." BAD IC if that measurement is done OFF the board, Notes 6 = VCC, 7 = GND.
ZD902 for the VCC clamping is not installed in your board.Leave a comment:
I looked over the document from the hyperlink posted by jiroy, but being an electronics neophyte, I wasn't able to get an useful information out of it to help diagnose my problem. Can someone more knowledgeable please help?Leave a comment:
Sounds like many links throughout this thread isn't working anymore so here is the Ic schematic .Attached FilesLeave a comment:
I soldered on a 47uf capacitor in place of the 33uf one for testing as you suggested. The output terminals still read zero volts. I measured resistance across pins 6 & 7 on the IC that's installed in the power supply again. I got 10.2 k-ohms if I put the red-color probe from the meter on pin 6 and black-color probe on pin 7. If I reverse the two probes, I got 4.2 k-ohms. I'm really confused. Why should reversing the meter probes make any difference when measuring resistance? I also measured the IC that I took out; that one measured 0.6 M-ohms with red terminal on pin 6. I have a 3rd IC that's supposed to be new. Resistance across pins 6 & 7 on that 3rd IC only measured 4.4 ohms. Are these ICs defective? I've attached a photo of one of the ICs with pins 6 & 7 marked (please see ic.pdf). Are those the pins I'm supposed to be measuring? What should the resistance be?
I also measured voltage across terminals 6 & 7 on the installed IC when I had the power supply plugged in to test; voltage was about 0.9 volts. I'm not sure about the zener diode. Can you tell whether I have one from the attached photos?Last edited by ptmy3; 03-16-2017, 11:57 PM.Leave a comment:
So you do have DCV to run that standby power supply IC (ICE)
I really do not expect to see 511 Ohm between VCC and GND.
Does your board has Zener diode between VCC and GND?
The 33uf cap with 11 Ohms ESR and shows as 25uF is not good, you can try 47uF in place for testing.Leave a comment:
Yes, the big capacitor had very high voltage (over 150V if I recall). I took out the 50V 47uF capacitor to measure ESR. ESR was really high (measured around 42uF / ESR 7.5 ohms), so I replaced that with a 47uF 160V cap, which was the only 47uF I had on hand. Power supply still output zero volts. I took out the small 33uF/25V capacitor (C924 I think) to test. That also has high ESR with below-spec capacitance (measured 25uF / ESR 11.5 ohms). Unfortunately, I don't have a good 33uF capacitor lying around. I have to order one online. I tested the other radial capacitors in-circuit with my ESR meter. ESRs were ok, but since I didn't remove the capacitors to test, I'm not sure results are all that accurate.
Resistance between VCC (pin 6) and gnd (pin 7) on the IC is around 511 ohms.
Do you think high ESR in C924 could be causing my problem? Should I just replace the other radial capacitors (maybe not the big one)? There are 2 x 10V/2200uF, 2 x 16V/2200 uF, and a 1000uf capacitor in there (what's the voltage on this 1000 uF; I can't read the voltage marking without removing the capacitor) .Last edited by ptmy3; 03-16-2017, 08:52 PM.Leave a comment:
Are you getting any DCV between the two legs of the main filter cap in the primary side?
We need to have that Voltage first to go further.
BTW, please upload straight shot pictures of the your board.
Also, what is the resistance between VCC pin and GND pin of that ICE IC?Last edited by budm; 03-16-2017, 07:18 PM.Leave a comment:
I know this is a really old thread, but I'm hoping someone knowledgeable is still looking at it once in awhile.
A few months ago, my 1800FP had no power when turned on. I repaired it by re-soldering D903 and D906, and replacing the ICE2AS01. Monitor worked great until yesterday when the problem returned - no power when turned on. I measured zero volts between both the 12V and 5V pins and ground on the output connector of the power supply. I thought I may have done a bad job with the soldering the first time, so repleted the exercise. I re-soldered D903 and D906, and installed a new ICE2AS01. But this time, it didn't fix the problem. I'm still getting zero volts on the output terminals. There are no bulges in any of the capacitors. I didn't see any obvious bad soldering joints but decided to re-flowed the solders with a heat gun anyway. But the problem persists. I also check to make sure pins 6 & 7 on the ICE2AS01 wasn't shorted; it wasn't. Anyone have a suggestion on how to proceed next?Leave a comment:
Well, surprise surprise! I didn't believe it would work but I replaced the IC ICE2AS01 and now it works. I bought it for $3.50 and it was the answer. What would I do without "BADCAPS.NET"?Leave a comment:
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
- Loading...
