Viewsonic VP211b
    Re: Viewsonic VP211b
    Originally posted by PCBONEZ View Post
    Butter knifes.
    Tried that. Next day the toast tasted funny.
    PlainBill
      They are supposed to be in the tool box.
      I suppose if you mix your tools and utensils like that you could use the putty knife in the kitchen drawer to spread things on toast.
      It's probably a better tool for that anyway.
      Mann-Made Global Warming.
      - Dr Seuss
        My shop teacher always insisted we use the proper tool for the job. Butter knives are used to spread butter, putty knives to apply putty. Every time I get out the guitar picks I check over my shoulder to make sure he isn't watching.
        PlainBill
          And dissecting picks are for dissecting and guitar picks are for picking guitar strings.
          The proper tool for a job isn't in it's name it's in what it does.
          - Dr Seuss
            We use old toothbrushes and Q-Tips for removing rosin from boards after soldering. And I read one enterprising member on this forum use a heated screwdriver as a soldering iron! I'm waiting for someone to pull a "Macgyver" and make a ESR meter out of a paperclip and 9V battery.
              Heated screwdriver, I like it! When removing bad caps before, my iron was too fat for some of the job, so I got a thick sewing needle in some pliers and heated it up with a little propane torch, worked a treat
                I had to bore a couple of holes in a PCB once and the ship was short on drills.
                Couldn't get my hands on one for days. Waiting list.
                I made a bow drill in the fashion of a fire starting kit [pic below] and used that to spin the bit.
                Took a while, but not as long as the waiting for a drill.
                - Dr Seuss
                  My VP211b produces a black screen upon powering up. The green power light comes on and after 30 seconds the green light switches to orange "power save mode". Note, I cannot access the OSD. I have recapped the power supply thinking that was the issue. But monitor responses they same way it did proir to the recap.
                  Any ideas as to what the problem may be?
                    Do you have a signal going to the monitor?
                      First, let me correct my original post. Prior to recapping the power supply the VP211b responding as follows: Black Screen, No OSD, Power light green then switches to orange. After recapping: Black Screen, No OSD, green power light steady and no longer switching to orange. Note, power light stays green on one of the signals when I switch to the second signal input option "via toggle switch" the light turns orange.
                        I do have the monitor connected to a computer so I think I have a signal going to the monitor. However, I have not verified the cable nor established the monitor in XP's system data.
                          Set the switch to where you get a steady green light indicating is good signal.
                          It may be difficult to see, but with a light shined on the LCD can you see an image?
                          Eventually you are going to need to provide photos of your power supply, and possibly the signal card and inverter if it is separate.
                          The members that try to help with LCD problems prefer that you would use the Managed attachments feature when you provide photos. A straight down shot without a flash, so the writing on the board is readable is best.
                            Been there, done that, never got the tee-shirt. Inverter power is routed through the signal card. The inverter has two (three?) fuses. If either is open, the backlights never come on.
                            I used a bench supply to power up the side with the blown fuse and verify it worked properly. Another option would be to hook an 1157 automotive light bulb across the open fuse. Of course, there is always the possibility of another problem.
                            PlainBill
                              just got my hands in one of those units, and the problem ended up being the logic board (besides the recap). I have some parts for those units, so I just swapped it and that was it. I will find time to troubleshoot the logic board in the future, but for now, that was the solution...
                              • ASUS ROG Maximus IX Code
                              • Intel Core i5-7600K 3.8GHz
                              • Windows 10 Pro x64
                              • GeForce GT1050
                                Hey Bill.....
                                I am playing with one of these right now and the fuses on the inverter are toasted...... What size are they? Do you or anyone know?
                                Keith
                                  Is there a letter on them, or a warning to 'Replace only with x Amp fuse'?
                                  PlainBill
